Iansmith Occasional Visitor
Posted: Thu Jul 14, 2005 8:42 am Post subject: Installing Speed cams onto TT3 |
I have Tom Tom Navigator 3, I have recently got POI Warner and trying to install. The POI Warner has installed OK but I cannot get the icon for the speed cams in the Properties\POI\icons to enable selection. I have checked that I copied accross the files ov2 & bmp and believe that I have although the only file bmp name I could see is pocketgps_uk_sc. I am assuming this is the correct file as it has the artists paper and brush as an icon. Any help would be gratefully appreciated. iansmithaqua@aol.com
Ian Smith |
xda Lifetime Member
![](modules/Forums/images/avatars/2206758954c7fc3ddae53f.jpg)
Posted: Thu Jul 14, 2005 10:12 am Post subject: |
If you go to herethere is an installation Word file that will explain how to setup the Speed cameras using CheckPOInt which is better than POI Warner. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Pocketgps Lifetime Member
![](modules/Forums/images/avatars/gallery/1_navigon_7110.jpg)
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Thu Jul 14, 2005 1:36 pm Post subject: Re: Installing Speed cams onto TT3 |
Iansmith wrote: | I have Tom Tom Navigator 3, I have recently got POI Warner and trying to install. The POI Warner has installed OK but I cannot get the icon for the speed cams in the Properties\POI\icons to enable selection. I have checked that I copied accross the files ov2 & bmp and believe that I have although the only file bmp name I could see is pocketgps_uk_sc. I am assuming this is the correct file as it has the artists paper and brush as an icon. Any help would be gratefully appreciated. iansmithaqua@aol.com
Ian Smith |
If as you say you are using POI-Warner then you need to convert the .ov2 files to .asc files, have a look on my web site, as you already have POI-Warner then follow the guide from after that point.
http://www.amngps4.wanadoo.co.uk/ |
