Pocket GPS World :: View topic - Installing Speed cams onto TT3
Iansmith
PostPosted: Thu Jul 14, 2005 8:42 am    Post subject: Installing Speed cams onto TT3 Reply with quote
I have Tom Tom Navigator 3, I have recently got POI Warner and trying to install. The POI Warner has installed OK but I cannot get the icon for the speed cams in the Properties\POI\icons to enable selection. I have checked that I copied accross the files ov2 & bmp and believe that I have although the only file bmp name I could see is pocketgps_uk_sc. I am assuming this is the correct file as it has the artists paper and brush as an icon. Any help would be gratefully appreciated. iansmithaqua@aol.com
Ian Smith
xda
PostPosted: Thu Jul 14, 2005 10:12 am    Post subject: Reply with quote
If you go to herethere is an installation Word file that will explain how to setup the Speed cameras using CheckPOInt which is better than POI Warner.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
Pocketgps
PostPosted: Thu Jul 14, 2005 1:36 pm    Post subject: Re: Installing Speed cams onto TT3 Reply with quote
Ian Smith
If as you say you are using POI-Warner then you need to convert the .ov2 files to .asc files, have a look on my web site, as you already have POI-Warner then follow the guide from after that point.
http://www.amngps4.wanadoo.co.uk/
Pocketgps
PostPosted: Thu Jul 14, 2005 1:39 pm    Post subject: Reply with quote
If the link to PoiEdit does no twork then try this one
http://www.poiedit.com/files/PoiEdit_v36r1.exe
22.071 (03 Jul 24)
