Pocket GPS World :: View topic - I'm looking for a GPS receiver for my XDA2?
The_Equalizer
PostPosted: Fri Jul 08, 2005 11:02 am    Post subject: I'm looking for a GPS receiver for my XDA2? Reply with quote
Hi Y'all
This is my first post. I have done a search to look through a few threads first.
I have an XDA2, & am looking to get a GPS receiver to be able to use with Tom Tom, mainly in the car.
I have been looking at various models.
There seems to be a few Solar powered ones about, but the reviews i've read in the reviews section has put me off a bit.
So, should i go for a bluetooth or an SD slot one.
Can anyone recommend a model for under £100. (well under, preferably. Laughing Out Loud)
Oh & one last thing, i need to be able to buy it in the UK.
Many thanks & great Forum. :D
regards
E
StevenGourlay
PostPosted: Fri Jul 08, 2005 11:25 am    Post subject: Reply with quote
have a look at
http://www.totalgps.co.uk/section503.aspx
There are a list of BT GPS.
Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool
andy-c1
PostPosted: Fri Jul 08, 2005 12:33 pm    Post subject: Reply with quote
i use the tomtom wired and have no problems at all ,as it takes away the bluetooth problems on the xda
TomTom 5001
The_Equalizer
PostPosted: Fri Jul 08, 2005 1:05 pm    Post subject: Reply with quote
Hi peeps
Thanks for the replies.
Andy, i don't understand what you mean. " I use the Tom Tom wired" Wired via what? SD slot ?
Sorry mate, really i'm new at this.
Clint
PostPosted: Fri Jul 08, 2005 4:16 pm    Post subject: Reply with quote
use a wired gps unit, they plug into the port at the bottom of the unit, and supply power to charge it up at the same time (just deselect "receive all beams" in settings / connections) - I had massive trouble with a bluetooth gps with tt3 it works but not with a bt headset, with vs5 it works but disconnects the gps when call is terminated, the wired unit combined with bt headset is fine with tt vs5, expect to pay around 35 quid for a compatible wired gps off e-bay of 50 locally - just remember the beam settings and you should be ok - is it an i or s model you have got? cheers mike
The_Equalizer
PostPosted: Fri Jul 08, 2005 11:36 pm    Post subject: Reply with quote
Neither
I got an original XDA II.
No S or i.
Thanks for all your replies peeps.
I'll check out a wired GPS Unit.
Got a feeling i will not be able to use it with my powered in car holder though.
Its a silver shield one. from pdamods.com.
E
Leon_Jabachjabic
PostPosted: Sat Jul 09, 2005 7:12 pm    Post subject: Reply with quote
Hi, Equalizer
Like you, I use the XdaII - with TT3 (I have decided not to try to persuade my better half to let me upgrade for the moment, as there seem to be a number of teething troubles with TT5).
I use a Rikaline X7 Bluetooth GPS and a Jabra BT250 headset in the car and have no issues with satnav/phone compatibility whatsoever (other then the fact that the phone screen obviously appears on top of the nav screen when on a call - but a simple poke at the 'minimize' cross on the phone app sorts that). Both Bluetooth devices function perfectly together.
Re Mikealder's post above: Bluetooth problems? What Bluetooth problems? (I have downloaded the latest ROM update from the O2 website, by the way).
Leon 8)
PostPosted: Sat Jul 09, 2005 8:36 pm    Post subject: Reply with quote
ok the problems i have had are down to the XDAIIs it will not work with tt3 and bt headset - the gps is fine but consider the fact that it is a phone and that doesn't work correctly, with vs5 better success with headset but in the end going wired got it to work as i need - phone first, sat nav second - this was not an issolated issue as the 2nd xdaiis did the same thing - i tried it just in case - mike
The_Equalizer
PostPosted: Sun Jul 10, 2005 11:58 am    Post subject: Reply with quote
Thanks again for the advice peeps.
I think i may play safe & go for a wired one for now.
I just bought a Silver shield in car, powered Cradle off of Fleabay. Can you use a wired GPS unit with it ? ?
its this one http://www.pdamods.com/proddetail.asp?prod=A1SSSPKMNT&cat=23
Will any wired GPS work ok with it.
It appears to have a connection at the bottom, marked GPS. ? ?
Thanks again.
E
PostPosted: Sun Jul 10, 2005 1:00 pm    Post subject: Reply with quote
It should be OK to use with that mount, just make sure the GPS unit comes with a compatable connector, tell them (the supplier) which mount you have, if they get it wrong send it back, the mount will also power the GPS through the same connector so you don't need extra cable running fron the power socket - I use a similar system with my 4700, the XDA set-up I have is a simpler system but works fine - Mike
The_Equalizer
PostPosted: Sun Jul 10, 2005 1:09 pm    Post subject: Reply with quote
Thanks Mike
Much appreciated.
Regards
E
andy-c1
PostPosted: Mon Jul 11, 2005 1:43 pm    Post subject: Reply with quote
some sites have a drop down selection
i just bought the tomtom gps just because it is theirs and cuts out any other problems like compatability
TomTom 5001
