Pocket GPS World :: View topic - TomTom Mobile 5 - C500 Install Problems
peterguk
PostPosted: Mon Jul 04, 2005 7:37 pm    Post subject: TomTom Mobile 5 - C500 Install Problems Reply with quote
OK, as title says, and i have read every post looking for the answer!!
New C500 on Orange contract. New TomTom 5 Mobile. Bought 512Mb miniSD card, and copied everything across (with hidden files showing).
Put card in phone, switch on.
Run TTM, and i select language, distance units and get to "select voice". I can test them all, but when i select one, nothing happens. I can exit back to home page.
So i try the patch. Install as per other posts here.
Run TTM, and i select language, distance units and get to "select voice". Except this time , in the middle of the screen it says "Install from CDROM or download from www.tomtom.com".
Arrrrrggghhh!! What am i doing wrong????
pwhooftman
PostPosted: Mon Jul 04, 2005 8:06 pm    Post subject: Reply with quote
1. don't install a patch for ttm5, that was for ttm4 to get it working with a non-TT gps only. So reinstall ttm5.
2. did TTM5 run fine on the original mini-sd? First run it once with the original, then switch to the new card.
peterguk
PostPosted: Mon Jul 04, 2005 9:10 pm    Post subject: Reply with quote
Thanks for your reply.
OK, so no patch, that's a start.
And i wasn't able to run the original card on my phone. I bought it for the 6680 wit O2, but after being mucked around, i decided to move to Orange and the SPV C500.
Because i had opened it, Dabs refused to exchange. I didn't bother arguing since all i had to do (or so i thought) was buy a miniSD and copy across.
pwhooftman
PostPosted: Mon Jul 04, 2005 9:29 pm    Post subject: Reply with quote
Hi, try this, the file currentmap.dat gets created the first time you use TTM5, so i think its missing from your SPVC500 (change map name if needed)::
If you run into problems in de MAP selection or the green "I Agree" screen do this:
Create a file called CurrentMap.dat in notepad with the following single line in it
" \Storage Card\Great-Britain-Map\
There is a single blank space after the final \ There is no closing "
Of course you can change the map folder name in the file to correspond with the map folder that you have.
Copy your new file to here:
\Storage\My Documents\TomTom
TuurG
PostPosted: Mon Jul 04, 2005 10:40 pm    Post subject: Reply with quote
Are you sure you have the correct version? You say you bought TTM5 for the 6680, but that is a Symbian phone. TTM5 is available in various versions, but not in the same product. So if you have the S60 version, it will never work on MS Smartphone
22.094 (25 Sep 24)
