Pocket GPS World :: View topic - TomTom5, Unable to get it to work with generic Bluetooth GPS
Stealth007
PostPosted: Fri Jun 24, 2005 1:38 am    Post subject: TomTom5, Unable to get it to work with generic Bluetooth GPS Reply with quote
Exclamation HELP!!!
Just purchased TomTom-5, installed it on my HP4150, works fine with my old wired TomTom GPS. Tried to install my Bluetooth GPS, HP4150 see's it fine, TomTom-5 doesn't see it with the program is run. Both Bluetooth ports have been tried without any joy. Also made sure that TomTom-5 was set up for other Bluetooth GPS Device.
lbendlin
PostPosted: Fri Jun 24, 2005 3:34 am    Post subject: Reply with quote
Make sure the BT receiver is set to NMEA. (not SiRF)
Do not try both ports, but use the prt that is identified as Outgoing Serial Port in your BT Settings. Use 38400 as the baud rate.
If it still doesn't work, select "other cable receiver" and select the same outgoing port.
Lutz
TomTom/TeleAtlas NAVTEQ
