Pocket GPS World :: View topic - TT5 + HP4355 + Pharos iGPS-BT + GPS360 Help!
2point8
PostPosted: Wed Jun 15, 2005 7:50 am    Post subject: TT5 + HP4355 + Pharos iGPS-BT + GPS360 Help! Reply with quote
I have an HP 4355 that TT3 worked great on, now with TT5, i can not establish a BT connection. I activate the BT connection within the BT manager, then go into TT5 and tell it to look on COM port 8 (or any port) and it always says no GPS device found. It's drivng me nuts b/c the setup worked flawlessly w/TT3. Also, should I let the pharos GPS sit and get a connection to the satelites before I attempt to connect? Is there a way I can see the port number for my active BT connection?
Just incase, here is my setup
TT5 + HP4355 (rom v1.1) + Pharos iGPS-BT + GPS360
2point8
PostPosted: Wed Jun 15, 2005 8:11 am    Post subject: Reply with quote
Dont you hate when you try to be a good internet user and use the search b4 asking a question, and when unseccesful you ask, only to find the answer 5 minutes later!?! Well, yea. If anyone is interested, i did it using the "alix776" method
Select "other wired GPS device" -> baud rate to 38400 -> select your OUTBOUND BT port and it all works
Thanks to all the geniuses on this forum!
22.063 (19 Jun 24)
