m70ppn Occasional Visitor
Posted: Sun May 22, 2005 10:44 pm Post subject: BT-338 connection problems |
Hi I was hoping one of you could help me, I have a XDA 2i I have installed tomtom 4, I have a BT 338 bluetooth GPS reciever. I am having trouble getting tomtom to connect to the bt 338. I have read all the advice on this and other forums and have still had no luck. I have downgraded the gps to 2.06 and 2.07 and still had no luck. When I activate tomtom the blue L.E.D. does flash faster so I think that is set right. When I check the Activity in bluetooth connection status there is no bytes sent or recieved. I have set the port and baud rates as described in the tutorial on this forum. Could someone please give me some help ive been at this for 2 days. Thanks. |
lbendlin Pocket GPS Staff
Posted: Mon May 23, 2005 1:36 am Post subject: |
Arey ou using other navigation programs besides TomTom? If not then you don't need to follow the article guidelines.
You should make sure that in the BlueTooth Manager of your Pocket PC you have connected to the Serial Port of the BT-338, and then in TomTOm 4 select "Other BT receiver" and pick the correct port (the outgoing serial port from your BT settings) _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon May 23, 2005 2:07 am Post subject: |
Hi thanks for your reply, I dont have the option for other bt reciever on the dropdown list, am I looking in the wrong place?? |
Posted: Mon May 23, 2005 2:10 am Post subject: |
Oh and i am just using it for tomtom.
And it is connected in bluetoth manager. |
Posted: Mon May 23, 2005 2:13 am Post subject: |
Just noticed in bluetooth it is connected to the BT-GPS COM Port not the serial port is this my problem |
Posted: Mon May 23, 2005 3:02 am Post subject: |
connected, as in - you see the two little green arrows?
InTTN4, go to Preferences >GPS status > Configure and select "Other Bluetooth receiver" there _________________ Lutz
Posted: Mon May 23, 2005 9:01 am Post subject: |
Hi yes I mean connected as in I have 2 green arrows in bluetooth manager. but no bytes sent or recieved.
Where do I find the Preferences part of TT, been l;ooking through the menu's and can't find it. |
Posted: Mon May 23, 2005 9:32 am Post subject: |
I think it's on page 5 or 6 of the preferences sequence. Just keep tapping the arrow. _________________ Lutz
Posted: Mon May 23, 2005 9:49 am Post subject: |
Hi I must be on the wrong cersion of tomtom or something, when you install it says version 4.0.0.1
BUt in the navigator menu I only have 3 pages.
Thanks for all the help you are giving me. |
Posted: Mon May 23, 2005 10:08 am Post subject: |
THis doesn't sound at all like TomTom. Can you please post the info displayed in the "About" screen? _________________ Lutz
Posted: Mon May 23, 2005 1:42 pm Post subject: |
Hi there seems to be no about screen. |
Posted: Mon May 23, 2005 1:45 pm Post subject: |
Ah found it.
Tomtom Navigator 3.00 (402)
English
Central |
Posted: Mon May 23, 2005 2:43 pm Post subject: |
Well that's why. You don't have TomTom Navigator 4 but TomTom Navigator 3. I'd recommend you update to 3.07 and then read the article about TomTom and BT receivers, That should help. _________________ Lutz
Posted: Mon May 30, 2005 10:58 am Post subject: |
Hi right ive upgraded to 3.07.
Still cant get a connection ive got it set to NMEA 0183v2 38400 and bluetooth serial port com6 can you confirm this is right.
Thanks |
Posted: Mon May 30, 2005 1:42 pm Post subject: |
Someone with the same device needs to confirm that COM6 is the outgoing serial port on the XDA IIi _________________ Lutz
