Pocket GPS World :: View topic - Mapsource MetroGuide Europe
PegSneggle
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Mapsource MetroGuide Europe Reply with quote
I am almost a new user, about to buy the Garmin eTrex Legend Europe package. I am a road cyclist in the UK and I like to plan routes of about 100 miles on quiet roads.
Does the Mapsource MetroGuide Europe software satisfy my required level of detail? Is the 8Mb available in the Legend enough for my application? If you can filter what elements of the map are downloaded (to minimise RAM usage), then I am only interested in roads and villages, not places of interest, petrol stations etc.
Thanks in anticipation
PegSneggle
In a word yes! MG Europe covers all A, B and many minor roads. You can't filter the seperate elements but you can limit the map area you download so 8mb for a 100 mile ride should be plenty. Roads & Recreation does not contain the address look up data so map segments are smaller and this may be a better option for your need.
obarnes
Mapsource MG UK 'segments' are about 6.5 to 8mb each.
Check the online map viewer - http://www.garmin.co.uk/cartography/ to see the level of detail and segment area's.
Hope this helps.
- Oliver
Tim Buxton
Bearing in mind that the chosen route might cover more than one segment, might not Roads and Rec be a better bet? The smaller segments mean greater selectivity is possible. Of course, the route planning of MetroGuide might also be a consideration.
Tim
obarnes
R&R segments are approx 25 miles diagonally across and the majority are between 100 and 300kb in size so you could fit 'approx.' 40 segments on an 8mb card...
You can fit the whole South of England (below Gloucester but excl. Wales & London) on an 8mb card.
As Tim says you may be restricted with MG unless you like cycling in big squares
- Oliver.
PegSneggle
Gentlemen
Thank you very much for all your help. I have now ordered my GPS and am looking forward to it arriving.
Your overpowering advice seemed to be that I should go for "Roads and Recreation", not "Metroguide".
Consequently I am buying "Metroguide". There is reason to this madness. Metroguide comes as part of a very reasonable package which includes machine, cable and Mapsource. There did not seem to be a similar package which included "Roads and Recreation". So I'll see how I get on and may have to buy the other eventually.
In the meantime, thanks again for all your help.
Best Wishes
Mike Wood
PegSneggle
22.124 (26 Dec 24)
