Pocket GPS World :: View topic - Nemerix Based GPS Receiver
DigiGuru
PostPosted: Tue Apr 12, 2005 11:27 am    Post subject: Nemerix Based GPS Receiver Reply with quote
Just thought I'd link through to this (my post) within the hardware section, as it's a cheap receiver. (< £50 inc vat + p&p! )
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=19207
PostPosted: Tue Apr 12, 2005 4:46 pm    Post subject: Reply with quote
beware though - we've seen reports that the factory settings include a different map datum (other than WGS84), resulting in a north offset of about 100 meters in some cases. At the moment we cannot recommend this receiver for beginners.
DigiGuru
PostPosted: Thu Apr 14, 2005 11:03 am    Post subject: Reply with quote
Hmm... ok :\
Is there a way to correct that?
If it's relatively easy, I can write an application quiet merrily to automate it ;)
Stu
DigiGuru
PostPosted: Wed Apr 20, 2005 11:20 pm    Post subject: Reply with quote
Can anyone confirm this is/isn't a problem, or if it's one that can be corrected?
Stu
DigiGuru
PostPosted: Thu Apr 21, 2005 10:10 am    Post subject: Reply with quote
I've found further specs:
Model Number: WD-N101
Receiver: Nemerix SoC/ RF IC
Sensitivity: Static -139dBm, Tracks -1 52dBm
Accuracy: 5-10m (does not have SA)
Precision: 1ms, <500 nanosecond
Ceiling: 18000m
Max Speed: 515m/sec
Max Acceleration: 4g
Geography Coordinates: WGS-84 (This IS standard)
Input voltage: 3.3V (+/- 5%)
Size: 25.9mm x 25.9mm x 2.7mm
Data Type: NMEA-0183 V3.0 and Nemerix binary system
Outputs: GGA, GLL, GSA, GSV, RMC, VTG
Baud rate: 4800/9600~38400bps
Operating Temp: -40°C ~ 80°C
Antenna: Built-in
22.063 (19 Jun 24)
