Pocket GPS World :: View topic - Bluetooth problem with hx4700 & Holux 231
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
Flyguy
PostPosted: Fri Apr 01, 2005 12:34 am    Post subject: Bluetooth problem with hx4700 & Holux 231 Reply with quote
I have had an "event" with my 4700, as a result of a sharp knock it froze and needed to be placed in its cradle to bring it back to life. It was completely reset.
I reloaded everything and all works well again except Tomtom cant see my Holux 231 bluetooth. (Bluetooth to mobile phone works fine)
I have it setup and paired in Bluetooth manager but niether Tomtom or the Gps viewer tool that came with the Holux can see it (even if I connect manually in Bluetooth manager and the Holux goes to fast blue flashing indicating a connection).
One puzzle is that Tomtom GPS Status used to see two Bluetooth ports Com 5 and Com 8 now all it shows is Com 5. I can't recall which I used to use.
Any ideas? When I first got the Holux I just paired it and away we went.
Thanks.
Guy
lbendlin
PostPosted: Fri Apr 01, 2005 2:43 am    Post subject: Reply with quote
Start > Settings > Communications > Bluetooth > Services > Serial Port > Advanced
Make sure the outgoing port is enabled
Lutz
TomTom/TeleAtlas NAVTEQ
Flyguy
PostPosted: Sat Apr 02, 2005 12:05 pm    Post subject: Reply with quote
It says Inbound COM Port: 5 Outbound COM Port 8.
I don't appear to be able to change these (it shows the Holux as the default device for outgoing serial connection) but Tomtom GPS only shows Port 5, Im sure it used to show Com 8 also but I can't recall which I used.
Guy
lbendlin
PostPosted: Sat Apr 02, 2005 2:24 pm    Post subject: Reply with quote
Correct - you need to use COM8. If that's not available then you need to uninstall the TomTom GPS driver ONCE, soft reset, and then try again.
See our TomTom BT guide for Smarties.
Lutz
Flyguy
PostPosted: Tue Apr 05, 2005 8:03 pm    Post subject: Reply with quote
Thanks, tried that (deleted Tomtom GPS via Activesync) - result was that GPS Viewer could see the Holux!
Bad news though Tomtom wont start!
Deleted all of Tomtom and reisnstalled it now I'm back where I was... Tomtom works but doesn't offer me a COM 8 option and GPS viewer says it can't open COM 8.
I feel I'm so close. Argh!
Guy
lbendlin
PostPosted: Tue Apr 05, 2005 8:35 pm    Post subject: Reply with quote
Lutz
Flyguy
PostPosted: Tue Apr 05, 2005 9:40 pm    Post subject: Reply with quote
I've removed the TT GPS via Remove Programs on the iPAQ but it doesn't come back - it just goes!
I have only removed it once since a complete reinstall. Version is 3.00 BTW.
I had it all working without this step before my hard reset.
Guy
Flyguy
PostPosted: Tue Apr 05, 2005 10:44 pm    Post subject: Reply with quote
I've just loaded 3.07 and it all works!
Thanks for your help.
Guy
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
