snooper Occasional Visitor
Posted: Mon Apr 04, 2005 7:22 pm Post subject: GPS Navigation problem |
I programmed the TT to navigate me to Grasmere Cumbria.
When asked to input city I input Grasmere,
When asked to input street I input Church Street.
The TT planned the route and off I set, however I would normally take the M6 to junc 40 however TT took me through Carlisle on to Cockermouth heading for Whitehaven. I realised 4 mile outside Cockermouth that I was not on the right route and reprogrammed to take me to Ambleside which was 1 hour in the opposite direction.
Why has this happened and if you input a town why does it always ask for a street, what if you don’t know any streets in the town your visiting as in this instance.
And if there is no church street in Grasmere then why does TT accept this?
Any suggestions?
Snooper
IPAQ RZ1710
TT Navigator vers 4.4
Belkin TuneCast II
Snooper S4 neo
Dashboard technology |
Hoppy Regular Visitor
![](modules/Forums/images/avatars/1602049154479f42608a734.jpg)
Posted: Mon Apr 04, 2005 7:56 pm Post subject: |
I worked out a route to Grasmere and without putting a street in just pressed OK and it took me right to the centre of Grasmere. I also did it to Grasmere, Church street and it took me to Ambleside. The only reason I can see for this is that they are both in the LA22 postcode area and as Grasmere hasn't got a Church Street it went for the closest place with one.
If you don't know a street in the town you want just press OK after you have found the town ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Mon Apr 04, 2005 8:44 pm Post subject: GPS Nav Problem |
Hoppy
Thanks for the reply.
However on Tom Tom Navigator version 4.4 if you press navigate to you are asked to input a city and you are asked to input a street. I am not aware of any way to not input a street you cannot just okay.
Unless you locate you destination on the map screen and hit the navigate to icon. |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Tue Apr 05, 2005 9:43 am Post subject: |
From what I remember with my last vist to the lakes, both of these places are in the same local authority area. Hence TomTom will assume they are actually in the same town! So although you put Grasmere it will give you a list of all the streets in that area, just so happened Chruch Street was in the wrong place!
It's one of the biggest reasons why you have to have a good idea where you are going on the map before you set out. And then you should go through the instructions step by step to make certain it is taking you to where you expected!
I'm thankful TomTom5 will have better facilities for doing this, I had that problem in Edinburgh when I wanted to go to St. Mary's Street but I mistakenly put St. Mary's Place, which is in an entirely different part of the city! |
Posted: Tue Apr 05, 2005 4:36 pm Post subject: |
As a Tom Tom Navigator user will I get a free upgrade to Tom Tom 5 and will this offer better facilities ie postcodes etc.
Will the upgrade include software and UK maps. |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Tue Apr 05, 2005 6:00 pm Post subject: |
snooper wrote: | As a Tom Tom Navigator user will I get a free upgrade to Tom Tom 5 and will this offer better facilities ie postcodes etc.
Version 5 is reported as using Full UK Postcodes, which should cut out a lot of confusion.
No. The uipgrade is software only but new maps should be available also, but at a cost. _________________ Richard
Robin2 Lifetime Member
Posted: Thu Apr 07, 2005 12:14 pm Post subject: |
If you don't know the names of any streets in the town you want to navigate to, there is an easy work round. When it asks you the street name, start to retype the name of the town. After the first letter the town name will appear in the street menu box. Click on that and TomTom will take you to the centre of the town you have entered.
Robin |
Posted: Thu Apr 07, 2005 5:42 pm Post subject: |
Robin2 Thanks for the work around.
Much appreciated
Snooper :P |
