Posted: Fri Apr 01, 2005 10:36 am Post subject:
Wow, the first couple of lines would have done! The first problem is that the third column, SPEED_CAMERA, should say "SPEED_CAMERA". Can I ask how this database was created and what was used to edit it?
The second problem is that all your POIs have the same name. Ideally all POIs should be uniquely identified. _________________ Tim
Not really sure how it was created, came to me in a csv file in this way.
They are speed cameras for Australia.
Posted: Fri Apr 01, 2005 12:19 pm Post subject:
Well then it looks like you'll have to edit the file manually, I'm afraid. However you do iy, you need each SPEED_CAMERA to be "SPEED_CAMERA_XX" _________________ Tim
Posted: Sun Apr 03, 2005 10:48 am Post subject: Working but no notification...
Thanks Tim, I added the quotes and they now show up on the GPS software, but do not seem to be notifiying...could this be due to the fact they are all the same name?..I have only just changed the names now so won't know until tomorrow whether or not I get notified now.
Posted: Sun Apr 03, 2005 10:18 pm Post subject:
It could be, I'm not sure. Are you sure you've set SmartST to notify you of Custom POIs? Press the left rocker then the arrow in the bottom right-hand corner. Tap Setup then use the arrows to get to the Active POI tab up. For each of your Custom POIs, you can set up a warning, but you can only do this if the "Active" box is ticked. (Even if they are not ticked, they will show on the screen; this is a known bug.) _________________ Tim
