Pocket GPS World :: View topic - TT3 on a hp jornada 928
oli1983uk
PostPosted: Thu Mar 31, 2005 5:46 pm    Post subject: TT3 on a hp jornada 928 Reply with quote
I have a hp jornada 928 running pocket windows 2002, i have seen on a couple of sites that tom tom 3 will work on this handheld but also some say it will not work. so does anyone here know if it will work or not? cheers for any help
jwl
PostPosted: Thu Mar 31, 2005 5:48 pm    Post subject: Reply with quote
Also does anyone know if it is possible to upgrade the windows 2002 on this to the 2003?
Or if it is worth doing.
alix776
PostPosted: Fri Apr 01, 2005 2:28 am    Post subject: Reply with quote
it szhould run ok on the 928 youll need a wired receiver and a cf card to get it to quicker disable show poi on map in the poi properties screen as for upgrade to 2003 sorry you cant the jornada was replaced by the ipaq as a product line
device Lumia 950 xl
mentalpostie
PostPosted: Fri Apr 15, 2005 2:50 pm    Post subject: Reply with quote
i can tell you 100% that it does work as i've had nav 3 running perfectly on mine for over 12mths now just hoping that nav 5 will be ok
but you do have to have a wired system and get a decent sized CF card for the maps i've found it best to install the main nav program into the actual memory of the 928 and then the maps and any addons onto the CF card
PostPosted: Fri Apr 15, 2005 3:05 pm    Post subject: Reply with quote
TomTom 3 will be the last version to support the SH3 processor used in the Jornada's. Version 5 only supports ARM processors.
There is no upgrade path to 2003/2003SE for your device nor will there be Sad
mentalpostie
PostPosted: Sat Apr 16, 2005 9:11 pm    Post subject: Reply with quote
according to my jornada it use's the arm processor not sh3 were there different versions made of this pda then
22.063 (19 Jun 24)
