Joined: Mar 12, 2005 Posts: 4 Location: Kidderminster
Posted: Sat Mar 12, 2005 2:20 pm Post subject: Safety Camera Download
I have an iCN 630 running V3.
From what I have read in the forum, I must have the only one that wasn’t made on a Friday, as it has worked straight out of the box, and have had no problems with it.
I do have a little problem with the import of points of interest.
I have loaded the Gatso, Redlight, Specs and Temp Safety Camera from the Pockets Webb site.
When I select Nearest POI then MYPOI and select Gatso or Redlight I get a list to choose from, so no problem there.
When I do the same thing for Specs or Temp, I get No Matching POI's and the list is empty, also I have no Specs or Temp icons appear on the map.
I have checked on the Settings, My Data, My POI the files are there with a tic in the box and they are active.
I have just loaded the latest 3.024 version witch has the Truvelo cameras and again these are missing also.??
Posted: Mon Mar 14, 2005 9:36 pm Post subject: Re: Safety Camera Download
When I do the same thing for Specs or Temp, I get No Matching POI's and the list is empty.
I have checked on the Settings, My Data, My POI all the files are there with a tic in the box and they are active.
Posted: Mon Mar 14, 2005 11:19 pm Post subject:
The problem is not as bad as I thought, as nothing was coming up in the list, I took it that the import of the Specs data had failed.
After reading past and many forum messages I came across one which tells you how to import the Pocket GPS Safety Camera data into Auto Route on the PC.
I did this and with the Specs location on the PC. I compared this to the 630 and all the missing cameras have been loaded, it’s just a bit off putting when you see a blank list!!.
