barrowfordred Regular Visitor
Joined: 04/09/2003 21:03:05 Posts: 79 Location: Barrowford, Lancashire
Posted: Fri Mar 11, 2005 9:15 pm Post subject: C500 & TT mobile |
I have TT mobile installed on my C500 but whenever I exit the program all my data is wiped including favorites. I am using the exit command within the program to exit , if I don't the back light stays on.
Any ideas????? |
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Sat Mar 12, 2005 11:36 am Post subject: |
Never seen this happen before, I'm running it on a C500 without problems. You may want to uninstall it completely, power cycle the phone and then try and re-install again just in case some DLL hasn't been copied across correctly. |
pcb007 Regular Visitor
Posted: Sat Mar 12, 2005 8:22 pm Post subject: |
The back light stays on because Tom Tom sets to what it was when the program is started. If Tom Tom was not closed down correctly then it will stay at never go out, if then Tom Tom is again started it will see the back light setting set to never then when you do close it down properly it will leave it set at never (if you can understand that). |
skysurfer Occasional Visitor
