Pocket GPS World :: View topic - Rikaline 6020 Locking up
bibson
PostPosted: Fri Mar 11, 2005 7:58 pm    Post subject: Rikaline 6020 Locking up Reply with quote
I have a GPs 6020 unit which when first installed worked fine. However, i left it in a powered down state for some time and had to reinstall tt3 plus the 6020 viewer.
Now there is only the 6010 driver available in tt3 (using 12 sats?) and after a very short distance using tt3, it just locks up. If i remove the CF6020 unit and slot it in, it just finds the sats again and repositions itself whilst still running tt???
Is this a driver problem 6010 instead of 6020?
Is it wrong searching 12 channels instead of 8??
Well confused as it did work fine before this power down and i dont think i have installed anything differently?
New to this, please help as i am now at a total loss???? Crying or Very sad
DavidW
PostPosted: Sat Mar 12, 2005 2:03 pm    Post subject: Reply with quote
Most CompactFlash GPSes (the notable exception being the SysOnChip CompactFlash Memory GPSes) don't need any kind of driver on a Pocket PC. What is described as a 'driver' is often just a diagnostic application.
I'd remove any Rikaline software and try without - also put back the versions of Navigator and GPS you used before if you know what they were. You may have installed different versions this time.
22.101 (03 Oct 24)
