Pocket GPS World :: View topic - BT-338 connection problems
m70ppn
PostPosted: Sun May 22, 2005 10:44 pm    Post subject: BT-338 connection problems Reply with quote
Hi I was hoping one of you could help me, I have a XDA 2i I have installed tomtom 4, I have a BT 338 bluetooth GPS reciever. I am having trouble getting tomtom to connect to the bt 338. I have read all the advice on this and other forums and have still had no luck. I have downgraded the gps to 2.06 and 2.07 and still had no luck. When I activate tomtom the blue L.E.D. does flash faster so I think that is set right. When I check the Activity in bluetooth connection status there is no bytes sent or recieved. I have set the port and baud rates as described in the tutorial on this forum. Could someone please give me some help ive been at this for 2 days. Thanks.
lbendlin
PostPosted: Mon May 23, 2005 1:36 am    Post subject: Reply with quote
Arey ou using other navigation programs besides TomTom? If not then you don't need to follow the article guidelines.
You should make sure that in the BlueTooth Manager of your Pocket PC you have connected to the Serial Port of the BT-338, and then in TomTOm 4 select "Other BT receiver" and pick the correct port (the outgoing serial port from your BT settings)
Lutz
TomTom/TeleAtlas NAVTEQ
m70ppn
PostPosted: Mon May 23, 2005 2:07 am    Post subject: Reply with quote
Hi thanks for your reply, I dont have the option for other bt reciever on the dropdown list, am I looking in the wrong place??
m70ppn
PostPosted: Mon May 23, 2005 2:10 am    Post subject: Reply with quote
Oh and i am just using it for tomtom.
And it is connected in bluetoth manager.
m70ppn
PostPosted: Mon May 23, 2005 2:13 am    Post subject: Reply with quote
Just noticed in bluetooth it is connected to the BT-GPS COM Port not the serial port is this my problem
lbendlin
PostPosted: Mon May 23, 2005 3:02 am    Post subject: Reply with quote
connected, as in - you see the two little green arrows?
InTTN4, go to Preferences >GPS status > Configure and select "Other Bluetooth receiver" there
Lutz
m70ppn
PostPosted: Mon May 23, 2005 9:01 am    Post subject: Reply with quote
Hi yes I mean connected as in I have 2 green arrows in bluetooth manager. but no bytes sent or recieved.
Where do I find the Preferences part of TT, been l;ooking through the menu's and can't find it.
lbendlin
PostPosted: Mon May 23, 2005 9:32 am    Post subject: Reply with quote
I think it's on page 5 or 6 of the preferences sequence. Just keep tapping the arrow.
Lutz
m70ppn
PostPosted: Mon May 23, 2005 9:49 am    Post subject: Reply with quote
Hi I must be on the wrong cersion of tomtom or something, when you install it says version 4.0.0.1
BUt in the navigator menu I only have 3 pages.
Thanks for all the help you are giving me.
lbendlin
PostPosted: Mon May 23, 2005 10:08 am    Post subject: Reply with quote
THis doesn't sound at all like TomTom. Can you please post the info displayed in the "About" screen?
Lutz
m70ppn
PostPosted: Mon May 23, 2005 1:42 pm    Post subject: Reply with quote
Hi there seems to be no about screen.
m70ppn
PostPosted: Mon May 23, 2005 1:45 pm    Post subject: Reply with quote
Ah found it.
Tomtom Navigator 3.00 (402)
English
Central
lbendlin
PostPosted: Mon May 23, 2005 2:43 pm    Post subject: Reply with quote
Well that's why. You don't have TomTom Navigator 4 but TomTom Navigator 3. I'd recommend you update to 3.07 and then read the article about TomTom and BT receivers, That should help.
Lutz
m70ppn
PostPosted: Mon May 30, 2005 10:58 am    Post subject: Reply with quote
Hi right ive upgraded to 3.07.
Still cant get a connection ive got it set to NMEA 0183v2 38400 and bluetooth serial port com6 can you confirm this is right.
lbendlin
PostPosted: Mon May 30, 2005 1:42 pm    Post subject: Reply with quote
Someone with the same device needs to confirm that COM6 is the outgoing serial port on the XDA IIi
Lutz
22.055 (29 May 24)
