Pocket GPS World :: View topic - BC-307 vs Ipaq2210 vs TTN 3.01 409 vs TTNGPS 3.07 417/421
Andyisgettingpissed
PostPosted: Fri Feb 25, 2005 12:09 pm    Post subject: BC-307 vs Ipaq2210 vs TTN 3.01 409 vs TTNGPS 3.07 417/421 Reply with quote
The GPS will flash from first turning on with ext antenna and no programs running. Not seen it flash without antenna.
Using the GPS info I can start it where it still flashes but no info on the GPS info tab. Grind to halt.
Using TomTom GPS I can select the CF with NMEA, Emtac and the TT Nav and when I go to tick it to lock on I get win busy for over an hour and it slows right down until I reset.
HELP!!!!!!!!!!!!!
Please.
Andyisgettingpissed
PostPosted: Fri Feb 25, 2005 1:02 pm    Post subject: Reply with quote
Now on TTN V3.07 (442).
No difference.
Sometimes I can tick the box to lock the setting in TT GPS if I choose any other port apart from the CF.
Any driver and any other port wil tick it straight away. Soon as I set to CF it dies.
Ipaq
PostPosted: Fri Feb 25, 2005 3:58 pm    Post subject: Firmware? Reply with quote
Hello,
What firmware is your 2210 running on? I have exactly the same setup but with firmware 1.10 & no problems.
(I am sure you know but to get firmware version soft reset & it will be in bottom right hand corner).
Andyisgettingpissed
PostPosted: Fri Feb 25, 2005 4:07 pm    Post subject: Reply with quote
Hi, it's 1.1 too.
I've hard reset my Ipaq now and installed only the GPS Info.exe and it still hangs when I choose start GPS.
The GPS is flashing as if it has a signal but I can't view any info.
Ipaq
PostPosted: Fri Feb 25, 2005 4:14 pm    Post subject: Time..... Reply with quote
Sometimes mine can take about 10 mins to get a fix if it has not been plugged in for a time, is it brand new??
my settings are as follows;
NMEA 0183v2 4800
CF
You also mention emtac? what & where is this?
Andyisgettingpissed
PostPosted: Fri Feb 25, 2005 4:49 pm    Post subject: Reply with quote
The Emtac CRUX driver was from the TomTom GPS software.
Mine has a fix within minutes now but if I try the GPS Info tab after starting and leaving a while it just hangs and doesn't show me any info.
I only have the GPS Info program installed now.
I presumed this should work without tomtom and any other pogram needed.
Andyisgettingpissed
PostPosted: Fri Feb 25, 2005 4:51 pm    Post subject: Reply with quote
It was new as of yesterday but it seems to get a fix no problem.....with the antenna that is.
Ipaq
PostPosted: Fri Feb 25, 2005 5:06 pm    Post subject: Coated windscreen Reply with quote
Are you trying it inside a car without the antenna? if yes what car. most modern cars have heat reflective coating on the front windscreen which almost stops GPS signals coming through.
Andyisgettingpissed
PostPosted: Sun Feb 27, 2005 9:40 am    Post subject: Reply with quote
I managed to get a signal outside without the antenna.
That is not the problem though. As soon as it has a signal and starts flashing after I've clicked Start GPS the whole thing locks up. I can't view the GPS Info tab screen and eventually I have to end task and it says the software isn't responding.
I have emailed GlobalStat support...
Andyisgettingpissed
PostPosted: Tue Mar 01, 2005 4:40 pm    Post subject: Reply with quote
Still no reply from GlobablStat.
I've returned my iPAQ and bought from another supplier but now I'm seeing loads of problems on these 3 pages that isn't filling me with confidence. Arrives Thursday.
Seems to be loads of problems with BC-307 setup.
22.094 (25 Sep 24)
