dabby Occasional Visitor
Joined: Nov 13, 2004 Posts: 31 Location: Brussels, Belgium
Posted: Wed Feb 23, 2005 7:22 pm Post subject: External Antenna Rikaline 6030 |
Anyone here had experience with putting an external antennna on a Rikaline? Did it make any difference, is it worth it?
Cheers |
rikaline_uk Occasional Visitor
Posted: Thu Feb 24, 2005 9:28 pm Post subject: |
What car do you have ?
The 6030 works well without external antennas. |
Posted: Sat Feb 26, 2005 10:01 am Post subject: |
Alfa 156 Sportswagon - I was wanting to hardwire the device to the car though rather than putting it on my dashboard... |
Darren Frequent Visitor
Posted: Sat Feb 26, 2005 10:56 am Post subject: |
It rather defeats the object of using a bluetooth GPS! If you did hardwire it you would still need access to it to switch on/off as it has a soft power button. It also requires 12v C so you'd need to retain the cigarette lighter power cable which contains the voltage reduction gubbins. _________________ Darren Griffin |
Posted: Sat Feb 26, 2005 1:19 pm Post subject: |
You have a certain point there it's not completely futile
Anyway, I grabbed myself on this-morning anyway while I was buying a brodit mount for my PDA. Indeed I will have to wire the BT GPSR into the car so that it's on an "always" on - that way I just leave the unit on and don't have to worry about the soft power-switch.
Indeed, when I bought the Rikaline I didn't think about the soft-power problem...
I think it's still worth having the BT GPSR because I can then use my BT PDA without any wires there to worry about.
BTW, I'm delighted with the Brodit powered mount! |
Posted: Sat Feb 26, 2005 1:32 pm Post subject: |
I forgot to mention - the 6030 does indeed work just fine without an antenna. I was struggling to find somewhere to place it and have sonce discovered there's a small document holder on the driver-side sun-visor and even though the GPSR is not in the window-screen I still get 4 satellites. |
rorywquin Occasional Visitor
Posted: Tue Mar 01, 2005 2:54 pm Post subject: |
I have a SAAB95 and I put the gps in the cubbyhole and it works perfectly there ! |
