Pocket GPS World :: View topic - Sound Alerts for TomTom Mobile (Axim)
icurr
PostPosted: Tue Feb 22, 2005 6:58 pm    Post subject: Sound Alerts for TomTom Mobile (Axim) Reply with quote
I have a Dell Axim with the TomTom Navigator installed. I'd like to install the sound warnings for speed cameras. How do I find out what version I'm running. I can't seem to find it anywhere. Then what do I do/go to proceed?
Thanks in advance.
DavidW
PostPosted: Tue Feb 22, 2005 8:21 pm    Post subject: Reply with quote
In any screen except the Navigator screen, chose File -> About, which will tell you what version of Navigator you're running.
Basically, you need to install CheckPOInt (2.0.2 from our downloads area recommended for the Pocket GPS World camera database), POIEdit and set up POI Sync.
Instructions on the POIs are here. I suggest you install those first.
For CheckPOInt, install the program through ActiveSync, run it, and then tap on its icon at the bottom of the Today screen. You need to go through each menu in turn. Once you've got the POIs installed, what you need to set up in CheckPOInt is fairly obvious.
icurr
PostPosted: Tue Feb 22, 2005 10:14 pm    Post subject: Hmmmm Reply with quote
Okay, so what does "Cannot retrieve proxy settings. Probably these are set to auto-detect or auto configuration" mean?
DavidW
PostPosted: Wed Feb 23, 2005 12:45 am    Post subject: Reply with quote
Does the information here solve that problem?
I can see, using a moderator privileged function, that you're using BT Broadband, BT Yahoo ADSL or similar - which doesn't use proxy servers. Make sure the "Automatically configure" check box mentioned in that FAQ is unselected in Internet Explorer.
22.064 (26 Jun 24)
