Simon1 Frequent Visitor
Posted: Tue Feb 01, 2005 11:36 pm Post subject: Backing up of SD Card |
It occurred to me today while I was installing the latest Safety cameras that I haven't a clue as to how to back up my SD Card in case it all goes to pieces.
I assume that I want to copy everything in the Storage Card folder onto my Hard Drive. If that's right, do I then simply copy it all back on if the Card needed reinstalling?
Should I copy any of the other folders/files onto my hard drive or are they all on the CD's that came with the unit?
[/url] |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Tue Feb 01, 2005 11:54 pm Post subject: |
Hello Simon1
Yes just copy it to a folder on your HD, but if you do ever copy it back, sometimes the nav system cannot see them, what i have found is that you need to make sure that the files on your HD when copying back to the card are not shown with any properties, e.g., if you right click the files before copying them back to card, make sure the Attributes are all clear, not Read Only or anything else and all should work OK. |
Posted: Wed Feb 02, 2005 11:39 pm Post subject: |
Brilliant! Thanks! Any other files you suggest copying to the HD? |
Posted: Thu Feb 03, 2005 12:21 am Post subject: |
Hello Simon1
What other files, well i regularly back up my whole system using ActiveSync - Tools - Full Backup, only takes a couple of minutes, then if you do a hard reset you can put all back in one go, after a hard reset just make sure that Regional Settings are set back to your normal region before using the ActiveSync Restore otherwise it will not restore. |
Posted: Thu Feb 03, 2005 7:33 pm Post subject: |
Many thanks!! :P |
Posted: Thu Feb 17, 2005 11:16 pm Post subject: |
Well, I finally got around to backing everything up tonight but when using ActiveSync, I went to tools/backup and restore. The Full Backup was checked but the file to save it into was greyed out. When I attempted the backup all I got was "Backup: Disk Full". I'm now doing an old fashioned copy of the SD card to the C drive which is taking a looong time.
What exactly is stored on the rest of the files that aren't under SD Card in the Navman menu?
Any idea why aSync isn't working properly? |
