Pocket GPS World :: View topic - Pocket GPS World Speed Camera Database
vanduk
PostPosted: Tue Feb 15, 2005 1:27 pm    Post subject: Pocket GPS World Speed Camera Database Reply with quote
Can anybody tell me if it is possible to display on the TomTom Map and Icon to show Speed cameras? If so how do I do it?
DavidW
PostPosted: Tue Feb 15, 2005 1:31 pm    Post subject: Reply with quote
If you've put the database files in your map folder, you need to enable the POI in the TomTom software. As you haven't said which version of TomTom software you're using, I'll guess at Navigator 3 on the Pocket PC. For that, you go to File -> Properties, and select the files you want displayed on the POI tab.
vanduk
PostPosted: Thu Feb 17, 2005 12:26 am    Post subject: Speed Camera Database Reply with quote
David, Yes it is TT3 and I have downloaded the Speed camera database and have the Speed camera in POI list however there is no Icon shown against this. It has been given a cross like a couple if other POI's which are displayed on the Map, however however there is no Icon for the Speed camera shown on map. I get warning the warning sound signals Ok. I would like to see Speed camera Icons on the Map if possible.
Ivan
DavidW
PostPosted: Sun Feb 20, 2005 8:26 pm    Post subject: Reply with quote
You need to copy both the .ov2 (data) and .bmp (icon) for each category you want to display to your map folder.
Exit TomTom Navigator (or soft reset) and restart it once you've done that, and you should then have the icons.
vanduk
PostPosted: Sun Feb 20, 2005 9:46 pm    Post subject: Reply with quote
David,
Many hanks for your help.
Ivan
vanduk
PostPosted: Wed Feb 23, 2005 12:11 am    Post subject: Reply with quote
David,
Sorry to trouble you again. Where do I get the Speed Camera .bmp(Icon) file from.
Ivan
DavidW
PostPosted: Wed Feb 23, 2005 12:39 am    Post subject: Reply with quote
There should be .bmp files corresponding to all the .ov2 files in the Speed Camera Database .zip.
If you install the files using POIEdit and the POI Sync service, that should install the .bmp files from the server.
vanduk
PostPosted: Thu Feb 24, 2005 12:17 am    Post subject: Reply with quote
David,
Many thanks for your help.
Ivan
xda
PostPosted: Thu Feb 24, 2005 3:30 am    Post subject: Reply with quote
David, POIEdit and the POI Sync Service will not download the Speed related Gatso, Mobile .ov2 and .bmp files. They seem to only be available by directly downloading the complete Pocketgps Speed Camera database Zip archive.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
DavidW
PostPosted: Fri Feb 25, 2005 8:06 pm    Post subject: Reply with quote
That's a "known issue" at present. Adding the 'speed categorised' files requires POI Sync to be reworked a bit; that should hopefully be done fairly soon.
xda
PostPosted: Sat Feb 26, 2005 3:30 am    Post subject: Reply with quote
Ok David, Thanks for that.
Graham.
Nokia 925 Windows 8
22.071 (03 Jul 24)
