woody1 Occasional Visitor
Posted: Sat Jan 01, 2005 10:38 pm Post subject: loading speed cameras to my pda |
Help I've got a medion 95000 from aldi and i cant get the camera positions to download to the pda . I think i've got it all int othe pc but nothing else seems to happen .all that happens is the poi handler ones down load in to the pda but thecameras on there seem not to show either . I have paid for both of the items needed , burt after was told that pocket gps was a lot better but i can't get it to run at all. all the help you got please send WOODY1 |
crankyman Occasional Visitor
Posted: Sun Jan 02, 2005 12:23 am Post subject: |
You'll need to convert the files before you can use them, also you'll need to manually copy the converted Pocket GPS World database files to your PPC to \program files\POIWarner M...\pois
Take a look at this thread http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=7948 and also the thread off that, that Bo Peep points to, should keep you amused for a while.
I know this thread is mostly concerned with the earlier version of Medion Navigator, but as long as you have the right version of POI Warner for your PPC the method is the same so it will work.
Good luck, (it's not as bad to do as it reads...Honest!) :D
Jon. |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Sun Jan 02, 2005 11:14 pm Post subject: medion |
thanks for the info , I will give it a try and let yo u know how i get on
WOODY |
Bond Occasional Visitor
Posted: Fri Jan 21, 2005 5:41 pm Post subject: |
Hi there
This is my first post so I hope this is in the right place? If its not.. then you will know why i ask the following....
HELP!!!!! I am running TOm Tom Navigator 3 on a Ipaq 2210 bluetooth pDA. I am trying to download the speed camera database and the poi warner software and making a right pigs ear of it..
Can anyone tell this I.T Midget.. the step by step basic way to install
1. POI WARNER and 2. SPeedcamera database.. I have attempted this with the following results..
1. The speed cameras show . only on " Map" view and not in navigator.
2. The POI Warner is there to choose to be enabled but doesn't work.
ANY HELP WOULD BE GREATLY APPRECIATED.
thanks
Bond. |
