mr_luv_pants Occasional Visitor
Posted: Mon Dec 20, 2004 12:18 am Post subject: TOM TOM Freezing every 20 mins!!!!!! |
Hello
Hi all new here!!!!
I have just bought Tomtom navigator 3. The first time using it, the TOM TOM program froze after 20 mins use approx. The PDA had not froze as I could shut down the TomTom program and restart it and it was ok for another 20 mins and then froze again. What can I do please?
using TT3
Blutooth GPS
HP Ipaq 2215 |
DavidW Pocket GPS Moderator
Posted: Mon Dec 20, 2004 6:13 pm Post subject: |
This could well be a memory card problem.
Please post the type (SD, MMC or CompactFlash), brand, size and any markings on the memory card you've installed the maps on.
For example, I'd post
1GB Lexar 32x SD card
LEXAR MEDIA
SD1GB-100M
1204452
A0405078
MADE IN U.S.A.
David |
Posted: Mon Dec 20, 2004 8:20 pm Post subject: |
Toshiba
SD 256 mem
0444IJ6562H
Also I have received an e mail from Tomtom who say that there are compatibilty issues with the GPS driver and a 2210. I have downloaded the latest version (3.070 and it still froze up. They then told me to disable the POI which I have done. Have not used it since to see if they is a problem.
JOHN |
Darren Frequent Visitor
Posted: Mon Dec 20, 2004 8:57 pm Post subject: |
I'm afraid the easiest solution by far is to get a CF Card and store your maps on that. _________________ Darren Griffin |
Posted: Mon Dec 20, 2004 9:05 pm Post subject: |
why? what is the difference. Also here is the copy of the e mail that TT sent to me:
Dear Mr hibberd,
Thank you for your e-mail.
Would suggest that you download and install the latest GPS driver (3.02).
www.tomtom.com Support/FAQs 'Update 3.07 for TomTom GPS for Pocket PC
http://www.tomtom.com/support/rightnow.php?p_prod_lvl1=%7Eany%7E&p_new_search=&p_search_type=&p_search_text=3.07
Perform a soft reset of the PDA.Go to Start/Settings REMOVE PROGRAMS and REMOVE the TOMTOM GPS'
then make another soft reset and install the 3.02 and then run a set again
If you are already using the 3.07 version please try the following.
Disable the POIs:
Navigator/Navigator menu/ properties/POI/Uncheck the upper box
We hope to have answered your question to your satisfaction.
With best regards,
The TomTom Customer Support Team
I really wanted to use the POI for gatsos. Can you suggest anything please?
JOHN |
Posted: Mon Dec 20, 2004 9:13 pm Post subject: |
Because the combination of a 2210 and BT GPS with maps on SD card is a known issue, if you search on those terms here you will see the history.
This only affects GPS Nav and maps, .mp3s and other files run fine off SD cards and indeed in some cases a few users have had success with SD but they are in the minority.
The issue does not manifest itself if you use CF Cards for map storage or if you have a non-BT GPS. _________________ Darren Griffin |
Posted: Mon Dec 20, 2004 9:16 pm Post subject: |
ok will transfer everything and let you know. |
Posted: Tue Dec 21, 2004 3:43 pm Post subject: |
If that's really a Toshiba SD card (though the codes aren't like those I recognise as a Toshiba manufactured card), the card shouldn't be a problem.
Don't forget that you don't need POIs displayed to use them in CheckPOInt or similar.
As Darren says, there are people who have found that the combination of an iPAQ h2210, Bluetooth GPS, TomTom Navigator 3 and SD card doesn't work well - putting your maps onto a CompactFlash card is one easy way out of the troubles.
David |
