rob_beale Occasional Visitor
Posted: Fri Dec 10, 2004 11:26 am Post subject: iPAQ 2210, tomtom3 and SD cards |
I had read on this forum that some people were experiencing locking up problems with the iPAQ 2210 and TT3 whilst using an SD card to store maps etc. I was having the same problem using a 512mg Kingston SD card. After planning a route, TT3 would lock up after about 5 minutes and would only restart after a soft boot. I had read somewhere that there may be a locking up problem using SD cards with TT3 and that Compact flash cards were more reliable. I tried using an IBM 1gig microdrive CF II card that I normally use in my digital camera. After installing all the software onto the card - TT3, maps, camera database etc, I went out last night and tried the new set up. I drove for about 45 minutes with no lock ups at all and everything working fine. I hope this is of some help to others out there experiencing the same problems. :D |
steveadi Occasional Visitor
Posted: Fri Dec 10, 2004 2:11 pm Post subject: |
i am using the same sd card a kingston 512 and i have"nt recieved any lock ups yet (touches wood) are you using a bt gps reciever or a wired gps reciever. only so i can compare before i go out and buy a cf card.
steve. _________________ tomtom go 720T |
Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Fri Dec 10, 2004 2:37 pm Post subject: |
The 2210 / SD Card lock up issue only affects BT Receiver users. _________________ Darren Griffin |
alix776 Pocket GPS Moderator
![](modules/Forums/images/avatars/6212487444319be6786243.jpg)
i thnk as well as sd card problems the way thev2110 reads sdcsrds maybe a problem to. it also seams the cf can go down to if you startbgetting a message saying unknown cad in socket one then get intouch with hp as has happened with mine im ive not sent it off yet as ive not had time to organise it _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Fri Dec 10, 2004 8:20 pm Post subject: |
steveadi wrote: | i am using the same sd card a kingston 512 and i have"nt recieved any lock ups yet (touches wood) are you using a bt gps reciever or a wired gps reciever. only so i can compare before i go out and buy a cf card.
steve. |
I'm using a Rikaline 6030 wireless.
Rob |
Posted: Fri Dec 10, 2004 8:25 pm Post subject: |
Darren wrote: | The 2210 / SD Card lock up issue only affects BT Receiver users. |
Well, all I know is that since I've changed from an SD to a CF card, I've had no problems. Before with the SD card, the system was totally unusable as it would lock up after 5 minutes or less every time.
Rob |
johnk Occasional Visitor
Posted: Sat Dec 11, 2004 7:41 pm Post subject: |
steve. |
I normally use Kingston CF card (Thanks to Darren's advice) and do not experience any problem at all. I also have a Kingston 512 SD card so I thought I had a go to see what happens: I did not experience lockups but got frequent drop-outs (beeping telling you "position unreliable"). It recovers fairly quickly though. I am using TomTom BT GPS. |
