Pocket GPS World :: View topic - HELP Field scouting information software
black_dog
PostPosted: Sat Jan 22, 2005 5:20 pm    Post subject: HELP Field scouting information software Reply with quote
I have an ipaq. I am looking for a software package to enable me to walk around fields log the gps info on the ipaq and then transfer this info in the form of a .csv file to my home computer. I am also seeking advice on gps receivers for my hp2210! my thoughts were for a cf connection to keep the unit portable. Is their any difference in accuracy between receivers if so which would be the most accurate.
lbendlin
PostPosted: Sat Jan 22, 2005 6:00 pm    Post subject: Reply with quote
Welcome to the forum.
Most topographical software will allow you to record waypoints and then to export them to your PC.
You can either use a CF receiver (but the CF slot is better used with a memory card) or a BT receiver - the latter gives you more flexibility with receiver placement and energy source.
If you use a BT Data Logger then you don't even need to rely on the topo software to record the waypoints - the receiver can do that automatically.
Lutz
TomTom/TeleAtlas NAVTEQ
black_dog
PostPosted: Sat Jan 22, 2005 6:23 pm    Post subject: Further help Reply with quote
Thanks for your prompt reply.
I would like the ability to record these points as polygons ie to enable areas to be calculated ( to measure areas of fields) could you suggest a program
