rcflyers Occasional Visitor
Posted: Sun Nov 14, 2004 7:25 am Post subject: TTN3 Map view?????? |
Can I select the map view in TTN3 and drive around with the map "following" the movement of the car?
At the moment, while in map view, I just drive off the edge of the map, as the map just stays static on the screen.
If this can be done, is it possible to still get warnings of speed cameras while in map view?
Thanks for any replies.
p.s. Everything works fine in Navigator mode, I would just like to see the arial view of my local area while driving. |
Steve999 Regular Visitor
Joined: Jun 20, 2004 Posts: 160 Location: Lincolnshire, England
Posted: Sun Nov 14, 2004 9:33 am Post subject: |
Select the 2D view while in Navigator and zoom out until you get the scale you want. That should give you what you are looking for.
Then select 'Guidance off' in properties.
Steve _________________ Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
Posted: Sun Nov 14, 2004 10:49 pm Post subject: |
I'll give that a go, Thanks. |
SteveW Frequent Visitor
Joined: 21/05/2003 22:54:59 Posts: 516 Location: Leicestershire UK
Posted: Sun Nov 14, 2004 11:52 pm Post subject: |
You will need to go into Properties (advanced) and turn off 2D automatic zooming also.
Steve |
