Pocket GPS World :: View topic - will belkin gps work with windows mobile 2003
rockhard
PostPosted: Fri Oct 29, 2004 7:21 am    Post subject: will belkin gps work with windows mobile 2003 Reply with quote
i'm thinking about getting one of the new window mobile 2003 smartphones (audiovox smt 5600). will the belkin gps work with it? I can put a sd card in the phone so memory won't be a problem.
PostPosted: Fri Oct 29, 2004 2:06 pm    Post subject: Reply with quote
It's not so much a problem of the BT receiver, it is more an issue with the BT stack on the phone. The newer 2003SE phones seem to lack some of the configuration options, resulting in the unability to configure the outgoing serial port. Make sure the Audiovox is not one of them.
All the receiver needs to support is a pairing code. Even though that is not required for GPS operation, the Smartphones are paranoid about security and only accept connections from paired (bonded) devices). This means that BT GPS receivers that do not have a pairing code (like the Deluo Blackbox) cannot be used with Smartphones.
rockhard
PostPosted: Fri Oct 29, 2004 10:59 pm    Post subject: Reply with quote
well let's say the bt can be paired. will the software run in the window mobile 2003 smartphones?
PostPosted: Fri Oct 29, 2004 11:07 pm    Post subject: Reply with quote
Pairing is just the first step. The Smartphone must then also expose the outgoing serial port. Only then you can be certain that the software will wokr (but that second condition is independent from the receiver and the software, it's solely dependant on the Smartphone)
22.064 (26 Jun 24)
