Pocket GPS World :: View topic - Does Memory Map allow "Goto" command?
Ninj
PostPosted: Fri Sep 17, 2004 9:01 pm    Post subject: Does Memory Map allow "Goto" command? Reply with quote
Hi all,
Just wondering if its possible to get MM to give a range and bearing etc to a pre determined waypoint like a Goto command?
Thanks for any advice
Rgds
Richie
PostPosted: Fri Sep 17, 2004 9:52 pm    Post subject: Reply with quote
Yes, so long as the Waypoint is recorded then it's a simple matter to selct it as a 'GoTo'. You then get an arrow and a info panel showing bearing and distance to waypoint.
MrT
PostPosted: Sat Sep 18, 2004 6:32 am    Post subject: Reply with quote
If it is a single point, you can insert a mark, select then select "Goto Mark" (right click on the PC). MM will then take you in a straight line to that mark.
If you want to follow a route, you create the route with waypoints, then select it, then select "Follow Route" and it will guide you to the next waypoint and when you reach that, point you to the following waypoint.
It will not work out a route for you, you have to tell it the points you want to go to.
Ninj
PostPosted: Sat Sep 18, 2004 8:48 am    Post subject: Reply with quote
Hi MrT
Thats great thanks. How do you select go to mark or follow route in the PDA version of MM?
Thanks again
Rgds
N|nj
23.061 (04 Jun 25)
