Pocket GPS World :: View topic - GPS position unreliable
moggy
PostPosted: Tue Aug 24, 2004 6:01 pm    Post subject: GPS position unreliable Reply with quote
i must program my axim5 with tomtom3 over 30 times a days as i'm a freelance courier.
oftem i get GPS position unreliable come up and it takes an age to locate. sometimes, i've even turned the whole thing off and driven to somewhere nearby.
anyone know why this may be happening?
is my reciever on the way out or are all the satellites on their dinner break or something.
i have it wired into a cradle which then takes its power from the cigarette holder.
i do have a bluetooth card but i've never used it?
any ideas?
PostPosted: Tue Aug 24, 2004 6:17 pm    Post subject: Reply with quote
- You don't say what GPS Receiver you have so it could be a flaw in that particular type of GPS. For instance Leadtek's are pretty reliable but there's been a lot of complaints about Rikaline's in the forums.
- If it happens on the same stretches of roads every day then it could be a mapping isssue.
- You may have an athermic windscreen
- The GPS may not have a complete clear view of the sky
- You may have some other electrical / RF equipment in close proximity or packing a punch and causing problems with the GPS
- You may have a faulty charging circuit, or your alternator may be putting out too much juice and this could be overloading the GPS circuit.
I could go on until midnight, but I'll stop there Wink
moggy
PostPosted: Tue Aug 24, 2004 6:39 pm    Post subject: Reply with quote
oops, so i didn't.
its the tomtom reciever. the silver diamond shaped one with the small hole to show the green light
Steve999
PostPosted: Tue Aug 24, 2004 10:51 pm    Post subject: Reply with quote
Don't Axim 5's have big problems with some SD cards?
What kind of memory card are you using? If it's a Chinese made one (Sandisk perhaps) then you may find the answer here as Tomtom will have a data access problem similar to that experienced by HP 2210 owners using a BT receiver http://sdprob.aximsite.com/
Steve
Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
moggy
PostPosted: Wed Aug 25, 2004 8:41 pm    Post subject: Reply with quote
the card is a 128mb maxell.
the problem seems worse when i use ukposcode?
when i input a new postcode, that is when is starts to have problems.
for example, i navigate to somewhere then once i have arrived i then come out of navigator then use ukpostcode again to input a new full postcode then i get the gps unreliable position again even though its just got me to my last destination.
maybe it is something to do with ukpostcode?
i'm at my wits end now as its costing me so much time
Steve999
PostPosted: Wed Aug 25, 2004 11:10 pm    Post subject: Reply with quote
I assume that you have your postcode software on the SD card along with your TT GB map. As your problem seems to come when you are accessing two data sources on the SD card, you may well be suffering poor data access speeds.
In order to eliminate the card as a source of the problem, try a different card. Either a high quality Japanese made SD card or initially, borrow a 128mb CF card and try that. They tend to be faster and more reliable.
Steve
Sygic
CoPilot
Nissan Connect
moggy
PostPosted: Thu Aug 26, 2004 5:26 pm    Post subject: Reply with quote
pardon my ignorance, but what exactly is a cf card? and what is so special about it?
also, would you have that in the pda alongside the sd card or not?
cheers
icsys
PostPosted: Thu Aug 26, 2004 8:51 pm    Post subject: Reply with quote
CF is compact flash. They tend to be faster and more reliable (and in many cases cheaper) than their size for size SD equivalent.
As you have an Axim x5 you will have both a CF and SD slot so you can use either format or both at the same time.
Using a CF card would show up any issues you may have with the SD card thus confirming or eliminating it as a problem Thumbs Up
Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
22.063 (19 Jun 24)
