Pocket GPS World :: View topic - BT-308 reset
BT-308 reset
barrowfordred
PostPosted: Thu Jul 29, 2004 9:37 pm    Post subject: BT-308 reset Reply with quote
I am currently in the process of resetting my BT-308 to regain NMEA, not sure this is worth it but......... anyway, the battery has run down to the point were all the LED's have turned off. How much longer do I need to leave it?
Thanks.
Mehanik
PostPosted: Fri Jul 30, 2004 8:49 am    Post subject: Reply with quote
Leave it for 15-20 hours.
Mikhail E. Veselov
http://www.globalsat.su
GlobalSat Russia
barrowfordred
PostPosted: Fri Jul 30, 2004 10:08 am    Post subject: Reply with quote
Thanks for that, I assume I then need to make sure that TomTom is set to NMEA or it will change back???????
Does the external receiver supplied run with SiRF?????????
barrowfordred
PostPosted: Fri Jul 30, 2004 4:53 pm    Post subject: Reply with quote
Been off now for 48 hours, started the bluetooth connection, started GPS Info, Com port 8, baud rate 38400, start GPS, cold start = $PSRF...OK, then nothing.................................... Crying or Very sad
Scan Com port would appear to nothing also, when this is clicked nothing at all happens?
crypto
PostPosted: Thu Sep 02, 2004 9:44 pm    Post subject: use TomTom to switch to nmea Reply with quote
Can't guarantee it will work but I had the same situtation. At the end everything worked. If I recollect well the last thing I did was switching from sirt to nmea in TomTom. Kill TomTom and start GPSinfo. It found it immediately.
Ron
Steve999
PostPosted: Fri Sep 03, 2004 8:43 am    Post subject: Reply with quote
I seem to remember that there was an issue with some BT-308 units that when switching back from Sirf, you need to select NMEA 01832v2 38400 rather than 4800 otherwise it wouldn't play. Try that.
You could also try Winfast Navigator and do a factory reset within that. Would still recommend you select 38400 first after the reset though.
Steve
Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
22.063 (19 Jun 24)
