Frazzle Regular Visitor
Posted: Wed Dec 22, 2004 8:53 pm Post subject: |
OFF THREAD.... RF Connector
Hi agian ELDAR, sorry I have only bad news on the RF connector front. The nearest I could get to the correct type would be a "reverse SSMB" which are as rare as hens teeth. I tried to get some but the supplier would only sell in quantities of greater than 100 !!!!
Another supplier wanted over 14 GBP each for some gold plated ones. I have not had the time to do any more hunting for the connector this month but may start looking again in January.
I have to wonder if it is now worth the hassle as the external antennas seem to be back in stock and this connector seems to be a real "odd ball" which could cost a lot to source. This may make a DIY mount modification uneconomic. I hate to be beaten though :-(
Tom Tom have been clever in using the custom RF connector but also flippin unfriendly as well ! Good marketing I suppose. |
Eldar Pocket GPS Moderator
Posted: Wed Dec 22, 2004 9:26 pm Post subject: |
OK, I'll have a browse myself, see what I can dig up. |
gingernut777 Frequent Visitor
![](modules/Forums/images/avatars/32233146843f2d18c31e6d.jpg)
Joined: Nov 03, 2004 Posts: 251 Location: Earth where else
Posted: Thu Dec 23, 2004 8:20 am Post subject: |
gingernut777 wrote: |
The battery IS SOLDERED into the unit.
This is why i said it needs soldering, if you try and do it yourself.
![](http://www.diegotorres.com.ar/mensajeitor/foro/caritas/sopum_18.gif) _________________ Using an A to Z
Sextant & Compass |
Posted: Thu Dec 23, 2004 8:53 am Post subject: |
gingernut777 wrote: | gingernut777 wrote: |
![](http://www.diegotorres.com.ar/mensajeitor/foro/caritas/sopum_18.gif) |
I'm sorry, but that's not what you said. You said that the battery IS SOLDERED into the unit, which is not correct. And no, it doesn't require soldering if you do-it-yourself provided you get hold of the right component, i.e. a battery with the leads. |
Posted: Thu Dec 23, 2004 9:17 am Post subject: |
Eldar wrote: |
That's the BIG Question.
Getting the Right Componant
As Frazzle said,
TomTom have been cunning, why they couldn't put it in a battery compartment, for easy changing is silly designing.
Still,it does it's job.
![](http://www.diegotorres.com.ar/mensajeitor/foro/caritas/120103_emA44_prv.gif) _________________ Using an A to Z
Sextant & Compass |
Posted: Thu Dec 23, 2004 11:28 am Post subject: |
Oh, have it your own way..... 8) |
atcol Occasional Visitor
Posted: Wed Apr 13, 2005 2:37 pm Post subject: |
Can somedy give me the correct reference to replace the battery of my classic TTG.
Many tks |
imapbox Regular Visitor
![](modules/Forums/images/avatars/507efefa41041d713a0b3.gif)
Posted: Wed Apr 13, 2005 5:48 pm Post subject: |
ok, guys. the pictues you saw was my dismantled TTGO unit.
it still is in fact.....
the battery can be taken out the unit without soldering at all. there is a connector at the end of the leads that goes onto the TTGO board.
so, to replace it -- no need for soldering, except, maybe, to transfer the wiring to your new pack.
with a screwdriver (torqx) you indeed can replace the battey within 15 minutes. In fact, I can disassemble and have the battery here in about 5 minutes..... |
Posted: Thu Apr 14, 2005 8:06 am Post subject: |
Could you be so kind to give the correct references for this battery.
Tks in advance |
slast Occasional Visitor
Posted: Tue Jun 28, 2005 1:38 pm Post subject: |
I realise this thread may be dead but can the Go be charged via the USB cable when connected to the PC?
Steve L |
smallfreak Regular Visitor
Posted: Tue Jun 28, 2005 1:59 pm Post subject: |
slast wrote: | I realise this thread may be dead but can the Go be charged via the USB cable when connected to the PC?
Steve L |
Probably not. TT advices that you charge your GO 300 fully before you try to update anything, so you do not get into troubles when the GO runs out of battery during the update. |
