nich Regular Visitor
Posted: Mon Apr 11, 2005 9:39 pm Post subject: |
Mines working fine. Looks good. |
MikeB Frequent Visitor
Joined: 20/08/2002 11:51:57 Posts: 3859 Location: Essex, UK
Posted: Mon Apr 11, 2005 9:40 pm Post subject: |
Tonyabw60 wrote: | Well its not working for me,keeps knocking me back to v4.2 |
What directories do you have in the root of your SD card?
This may be the cause of trouble TomTom have reorganised the SD structure and added some new directories.. _________________ Mike Barrett |
bmwman Regular Visitor
Joined: Mar 26, 2005 Posts: 73 Location: Solihull, UK
Posted: Mon Apr 11, 2005 10:34 pm Post subject: |
Working a treat. QWERTY keyboard, customisable display, saveable itineries etc etc etc. Superb. This version is the dogs danglies. :D
Rich |
Tonyabw60 Occasional Visitor
Posted: Mon Apr 11, 2005 11:18 pm Post subject: |
Hi Mike
I have 11 files, 2 navigator maps (GB, and Main Roads of europe)
2 chk files
ttsys file
sys file
engf.vif
current map dat file
instal.bif
ttgo.bif
mac paint image
think thats about all.
Tony |
Posted: Mon Apr 11, 2005 11:24 pm Post subject: |
This is interesting as my card has a lot more directories in it.
Now I am wondering if this is bacause I effectively have a full version 5 install fron scratch. Tomorrow I will pull out my old 4,42 card and do an update on it and see what I get. _________________ Mike Barrett |
Posted: Tue Apr 12, 2005 12:36 pm Post subject: |
Mike
I had the 4.42 version running and updated to 5v no problem. |
Posted: Tue Apr 12, 2005 12:57 pm Post subject: |
I just updated my 4.40 system using 314 maps.
The whole process was totally painless, and I wasnt asked to activate the maps again. The final CD root directory image looks like the following:
The itn directory wasnt there when I completed the upgrade, but appeared after starting the application after the upgrade. _________________ Mike Barrett |
Boxbrownie Lifetime Member
Joined: 22/03/2003 16:18:25 Posts: 128 Location: United Kingdom
Posted: Tue Apr 12, 2005 5:49 pm Post subject: |
Great upgrade, now I can actually see the speed on the screen easily, and I love the way it turns on automatically when you clip it on the car mount.....great!
best regards David |
Posted: Tue Apr 12, 2005 5:50 pm Post subject: |
Hi Mike
What I noticed was that when are asked to select Instal Apllication it doesn't come up with V5:00 as V4.42 did.
Tony |
Oldboy Pocket GPS Moderator
Posted: Tue Apr 12, 2005 5:54 pm Post subject: |
When I installed V5 on mine and also a friends, I was asked to activate the maps! So what is different?
Not a great problem, but puzzling. _________________ Richard
Gus607 Occasional Visitor
Posted: Tue Apr 12, 2005 6:50 pm Post subject: |
Installed v5 no problem, did not have to activate, why do some people have to re-activate ?
My only comment is that when I switch the engine off and TTG is fed power via the cig lighter then TTG turns off, no sweat I know but diferent.
V5 worth waiting for. |
AshleyHinton Occasional Visitor
Joined: Dec 13, 2004 Posts: 30 Location: Oxfordshire UK
Posted: Tue Apr 12, 2005 6:51 pm Post subject: |
Upgraded to V5 all ok here, using the latest version of TamTam for Macintosh.
The only slight niggle was that audio warnings for POI's stopped working, because they've changed some of the sounds I guess.
Going back into 'warn when near poi' and re-allocating the sounds for our beloved revenue cameras did the trick.
I notice that the warning I use, the siren-sounding one, now goes three times which gives more of an alert when nearing a "safety" camera.
So far so good - I like the new software. Being able to customise the display is excellent (as are lots of other things!)
Ashley |
Hi Richard
Mine won't take the v5 upgrade for some reason,every time I try it goes back to version 4.2???????
I have even reformated the card and loaded the TTG software from the
CD that comes with the unit and done the upgrades from TT website all ok until I try v5 and it wont have it, so I don't know now what needs to be done to sort it.
I dont have anything like that number of files in the root of the SD card.
It will all work out in the end I suppose.
Tony |
Posted: Tue Apr 12, 2005 8:05 pm Post subject: |
Tonyabw60 wrote: | Hi Richard
Tony |
I saw somewhere that this problem has happened before, and the TTG SD card had to be copied to the PC, the SD card was cleared (deleted) and V5 installed. The Map folder was then copied back to the TTG and re-activated. I don't know if this is the solution for you though. Worth a try.
Lutz has also re-done the warning sounds for the data.chk. _________________ Richard
clivers Regular Visitor
Joined: 03/07/2003 09:14:39 Posts: 185 Location: Portsmouth, Hampshire, UK.
Posted: Tue Apr 12, 2005 9:59 pm Post subject: |
when you run the update, i suggest that when the installer says its finished leave your go plugged in for at least a minute afterwards.
if you unlug it straightaway you will find it has not completed the update. _________________ Ipaq 3970, Ipaq 2210 X2, Smart ST V1, Tomtom V3+V5, CoPilot V5, AA Navigator, Tomtom Bluetooth GPS, Navman 3450i Jacket, Navman Bluetooth GPS, Holux GM270, Fortuna GPS-PocketXtrack
, Tomtom GO V5 Classic, Road Angel Classic. |
