Pocket GPS World :: View topic - mapsonic and installing POI
dpick
PostPosted: Sat Apr 09, 2005 10:15 am    Post subject: mapsonic and installing POI Reply with quote
Can you help I have mapsonic on tungsten T2 works ok only 1 problem. I can setup a POI called home in mapstore on pc use it for departure or arrival point for navigation on pc no problem. How do I export or create on PDA (had to use right click on mouse to create on pc)
Thanks dave
elan2s
PostPosted: Mon Apr 11, 2005 9:08 am    Post subject: Reply with quote
In roughly the same way as on the PC except you use simply press and hold the stylus at the location and then select add POI. You might want to set up a new POI category first (such as Favourites) you do this in Parameters under the File Menu
dpick
PostPosted: Mon Apr 11, 2005 3:31 pm    Post subject: Thanks elan2s Reply with quote
Tried as you say worked first time. Could you also tell me how to export speed camera and postcode info to pda tried to convert to .sac and hotsync says not a palm file type and quick install just goes through install process and leaves file still on pc without installing it.
elan2s
PostPosted: Mon Apr 11, 2005 11:04 pm    Post subject: Reply with quote
To add these you will need v2.5 of Mapsonic which included POIManager
I described the way to incorporate the speed camera data in a previous post (http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=14058). This was written before the restructuring with different directories but still works fine, the files you want are in the .ov2 directory or if you want the speed zoned ones then use the .ov2 and .bmp (you'll still need to resize these as described) files in that directory. You cannot change the warning sounds within Mapsonic. Not sure on the postcode data but the principle is the same.
Hope that helps. Also you may find dedicated Mapsonic Forum more useful as this Palm one seems to have a greater focus on TomTom
dpick
PostPosted: Tue Apr 12, 2005 10:37 am    Post subject: Reply with quote
Thanks I have now got a bit further I have been able to download the icons for the speed cameras to mapsonic and can see them using the the "type of POI". have been able to hotsync the POI files using POI Manager (checked the log no problem reported) but I cannot see them on screen when using mapsonic (have panned across map nothing displayed) does this only work when using GPS on the road.
Thanks Dave
PS looked at Mapsonic forum found it empty unless I looked a wrong one.
elan2s
PostPosted: Tue Apr 12, 2005 1:39 pm    Post subject: Reply with quote
Zoom needs to be 6 or less to see POIs also you need to select them for display (and warning if you want) in the Parameters menu on the PDA.
The Mapsonic forum is certainly not empty. Here's the link in case you had the wrong one http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewforum&f=65
