Pocket GPS World :: View topic - Reluctant GPS fix
Reluctant GPS fix
whoamiifnotmyself
PostPosted: Sun Apr 10, 2005 5:05 pm    Post subject: Reluctant GPS fix Reply with quote
Hi all,
New to this GPS malarky and in need of some advice. My Navman 650 works OK most of the time, but on the odd occassion when I power on it takes an age to get a GPS fix, 5 - 10 minutes and then its fine, the worst was midnight Saturday when it took nearly 30 minutes to get a fix, again it was fine once fixed on.
So any clues or is this normal GPS downtime??? or have I got another Navman faulty unit?
robertn
PostPosted: Sun Apr 10, 2005 10:39 pm    Post subject: Reply with quote
You don't say if you were moving or not. If you are moving the GPS will generally have more trouble getting a fix. The otehr thing I have noticed is that windsheild wipers can cause a problem getting a fix - was it raining?
An external antenna will normally improve fix times and is worth considering.
whoamiifnotmyself
PostPosted: Mon Apr 11, 2005 11:03 am    Post subject: Reply with quote
Thanks for that robertn, yes I was on the move and no to the wipers. I have tried it stationary and it seems to get a fix much quicker, think I will order an external antenna as suggested, but £40 (GBP) is a bit steep for what it is! Any cheaper sources anyone?
limebear
PostPosted: Fri Oct 14, 2005 6:44 pm    Post subject: Reply with quote
A couple of times my 630 got its GPS firmware corrupted and was working but only just, with poor sensitivity and ages to get a fix.
Solution is to power up while holding the OK button, then select GPS menu and do a cold GPS restart. After first fix it's fine again.
22.063 (19 Jun 24)
