Pocket GPS World :: View topic - kingston 512mb card problems, red cross
andyfireblade
PostPosted: Tue Apr 05, 2005 12:39 pm    Post subject: kingston 512mb card problems, red cross Reply with quote
Hi all,
Just joined the forum as I have a problem with my newly purchased sd card (kingston 512mb). When I put the data onto the new card and switched the unit back on I get a red cross that appears through the card on the screen. If I reconnect the usb cable and check the card, the data is there. I backed up the old card to my pc and then cut and pasted the data to the new card, what have I done wrong??
Andy.
lbendlin
PostPosted: Tue Apr 05, 2005 2:42 pm    Post subject: Reply with quote
What format have you used to format the card? Try FAT16.
Lutz
TomTom/TeleAtlas NAVTEQ
linrew
PostPosted: Tue Apr 05, 2005 7:25 pm    Post subject: Reply with quote
hi
one of the guys i work with had the same problem and it turned out he installed the maps but forgot to click on install the application from the cdrom
to cure this you can just install the application from the disk or format your new card and start again installing the application first then the maps
hope this helps
andy :D
andyfireblade
PostPosted: Tue Apr 05, 2005 8:38 pm    Post subject: Thanks Reply with quote
Thankyou to both of you for your expert advice, everything is working fine after i tried what you suggested, many thanks,
Andy.
22.064 (26 Jun 24)
