Pocket GPS World :: View topic - Help with POI-Warner
ianr17
PostPosted: Tue Mar 29, 2005 7:18 pm    Post subject: Help with POI-Warner Reply with quote
Hi all i have the "Aldi" Medion9500/Mio168,i some how managed to leave it on for quite a few hours & it went completly flat.
I have lost my POI-Warner..so my question is how do i get it back on ? do i have to pay again or just D/load & use my original Reg No's etc...??
Ian
Pocketgps
PostPosted: Tue Mar 29, 2005 10:27 pm    Post subject: Reply with quote
Hello Ian
You should just be able to use your old reg number if you have not changed your PDA.
There should be a copy of POI-Warner on your main PC, just double click it when your Pocket PC is connected via ActiveSync, or as you say, download it then use your original reg number.
ianr17
PostPosted: Sat Apr 02, 2005 4:59 pm    Post subject: Reply with quote
right then, i have reinstalled POI-Warner & updated the Camera base,my problem now is that i cant get the Icons to show on my map....it must be a setting but which one...???
Cheers for an info
Ian
Pocketgps
PostPosted: Sat Apr 02, 2005 8:18 pm    Post subject: Reply with quote
Hello Ian
Just click the link at the bottom of my post and all will be revealed.
ianr17
PostPosted: Mon Apr 04, 2005 1:30 pm    Post subject: Reply with quote
well i've followed your site since you first posted on here about it...& very good too i might add.I still dont have any icon showing on my maps
Any ideas....??
Ian
Pocketgps
PostPosted: Mon Apr 04, 2005 7:10 pm    Post subject: Reply with quote
Any ideas....??
Ian
Have you activated the poi's in POI-Warner, if you have then I would try copying the Icon files to the poi folder again via ActiveSync.
Also in POI-Warner, make sure that the settings are correct as it is possible to have them activated but not showing, just check all of the settings.
ianr17
PostPosted: Mon Apr 04, 2005 7:25 pm    Post subject: Reply with quote
Right then,just rechecked all my settings then got active sync on the go & checked my POI folder on PPC....guess what..!!!??? i hadnt put on the bitmap images Embarassed
They are now on there & all is working fine....
Cheers once again
Ian
Pocketgps
PostPosted: Mon Apr 04, 2005 7:41 pm    Post subject: Reply with quote
Hello Ian
Easy mistake when setting it up after a hard reset, if you connect to your mio168 via ActiveSycn when you have it all setup again the way you like it, then on the ActiveSync Tools menu, select Backup and do a FULL Backup, then if you have to do a hard reset then you can just load everything back again without all the hassle, just make sure before trying to do a restore that the Regional settings (on you mio168) are the same as when you backed it up or it will say that the backup file is not correct.
22.094 (25 Sep 24)
