marcsf1 Occasional Visitor
Posted: Mon Apr 04, 2005 2:31 pm Post subject: plse can anyone help ? |
i have purchased a medion mdppc250 and have installed POI WARNER on it and i have downloaded the pocket gps database what i cant seem to figure out is which files i need to use and where they need to be saved on the ppc in order to locate them with poi warner can any of you good peeps out ther assist i would be grateful as a newbee to this gps stuff :D
thnx in advance marcsf1 |
Oldboy Pocket GPS Moderator
Posted: Mon Apr 04, 2005 7:39 pm Post subject: |
You need to go into POI Manager in Warner and select which files you want to use. When you connect to a PC that is on-line you synchronise and Warner will download the files you want and automatically put them in the right place. Is that any help?
On their website you can follow through several functions. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Mon Apr 04, 2005 7:49 pm Post subject: |
Hello marcsf1
Have a look on my web site, it is not for your unit but may help you install the Safety Camera data from this web site and show you how to setup POI-Warner.
Click the link at the bottom |
Posted: Tue Apr 05, 2005 1:34 am Post subject: thank you |
a big thnx to oldboy and pocket for your reply the help was much appreciated and well what can i say your info works fine a big thnx one again to you both regards marcsf1 :D im happy it works |
intense2002uk Occasional Visitor
Posted: Thu Apr 07, 2005 7:45 pm Post subject: medion mdppc250 |
how did you get your medion to connect via youre pc ??? |
Posted: Thu Apr 07, 2005 9:30 pm Post subject: |
Hi intense first you have to install the sync software (that was supplied with the medon pocket pc) on to your pc also connect the usb lead during installation the software will prompt you to connect the medion to the computer. hope this helps if not then jst let us know what your doing and well try to help :D regards marcsf1 |
