ShirleyTemple Regular Visitor
![](modules/Forums/images/avatars/39660440245fe9ac1e9aa4.jpg)
Joined: Feb 11, 2005 Posts: 141 Location: Southampton/Portsmouth
Posted: Fri Apr 01, 2005 10:38 pm Post subject: csv or speed zoned??? |
What's the difference between the "csv" files and the "speed zoned" files. I presume that the "speed zoned" icons have the speed or something on them, but which ones do I install? Are they the same cameras but with different info associated with them or should I be installing all of them? _________________ Navman iCN 520 |
Oldboy Pocket GPS Moderator
Posted: Sat Apr 02, 2005 8:08 am Post subject: |
The .CSV file are Excel files. When you download the .ZIP file there is a Text File included which is called 'Which Files Should I Use', or something like that.
Basically the cameras in the speed zoned files are duplicated in the un-zoned files. This link will also explain. _________________ Richard
xda Lifetime Member
![](modules/Forums/images/avatars/2206758954c7fc3ddae53f.jpg)
Posted: Sat Apr 02, 2005 9:07 am Post subject: Re: csv or speed zoned??? |
ShirleyTemple wrote: | What's the difference between the "csv" files and the "speed zoned" files. I presume that the "speed zoned" icons have the speed or something on them, but which ones do I install? Are they the same cameras but with different info associated with them or should I be installing all of them? |
In the CSV folder there are 6 .CSV files these are the base files that include all the cameras, if you don't intend going across the channel then you won't need the continental one. If you then open the Speed Zoned folder, There are another 2 folders, Gatso and Mobile in each of these two folders are the Speed Related CSV files. If you decide to use them then you won't need the pocketgps_uk_gatso.csv or the pocketgps_uk_mobile.csv from the first CSV folder. If you decide to use the Speed related .csv files you will also need the.bmp files from the speed related .ov2 folder. Hope this makes it clearer. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Sun Apr 03, 2005 8:58 pm Post subject: |
Thank you all for your patience. I think I've got now. By jov I think he's got it!!!
Is there a web site that gives the same camera info for other countries such as France & Spain that's in English of course? _________________ Navman iCN 520 |
