Pocket GPS World :: View topic - Rikaline receiving peoblems
flyboy63
PostPosted: Fri Apr 01, 2005 5:46 pm    Post subject: Rikaline receiving peoblems Reply with quote
I am having problems with a Rikaline 6030 It takes a long time to warm up and drops signals. I have an IPAQ1940 running TomTom 3.7 can I test the receiver with the winfast? if so what settings am I looking for and how do I do it?
I have my gps settings on Rikaline 6010 on com 8 I have tried other settings but they all seem to have the same results.
Retired and loving it!
PostPosted: Fri Apr 01, 2005 8:27 pm    Post subject: Reply with quote
Winfast may not work out to well, better try Crux_View. The speed is normally 38400, although most BT receivers are autosensing and adjusting to whatever you specify.
You may want to try connecting an external antenna to see if that makes a difference
flyboy63
PostPosted: Fri Apr 01, 2005 8:34 pm    Post subject: Rikaline Reply with quote
Thanks but how do I go about doing the tests and which external antenna would you fit. Where can I get a copy of crux_view?
Bill
PostPosted: Fri Apr 01, 2005 10:52 pm    Post subject: Reply with quote
Crux_View can be had from our download section (Emtac tools)
flyboy63
PostPosted: Fri Apr 01, 2005 11:34 pm    Post subject: Rikaline Reply with quote
thanks for the info but how do I use the program? sorry for being so thick!!!
PostPosted: Sat Apr 02, 2005 1:48 am    Post subject: Reply with quote
Start Crux_View, then specify COM8 and 38400, then tap on "open" after a short while you should see the sat numbers and signal levels. using the other tabs you can see more information, or change the programming of the NMEA sequences etc. Once you are done, go back to the first tab and click on "exit"
flyboy63
PostPosted: Sat Apr 02, 2005 10:13 am    Post subject: Reply with quote
Thanks, but it sounds like I could do a bit of damage going into other settings and changing them. To a country boy like me its all a bit sacry.
any advice on what I should be looking for?
Bill
flyboy63
PostPosted: Sat Apr 02, 2005 10:17 am    Post subject: Reply with quote
Just found the manual on the site!! I will work my way through it. Anything I should be looking out for?
Bill
23.054 (28 May 25)
