Pocket GPS World :: View topic - Importing POIs Error "No POI's Found In Input File"
Golden_Monk
PostPosted: Fri Apr 01, 2005 7:01 am    Post subject: Importing POIs Error "No POI's Found In Input File" Reply with quote
Hi There
I am trying to import a speed camera CSV file into my NAVMAN PiN, has SmartST V3.
Getting the error "No POI's found in input file".
Here is the contents of the file...
hope you can help, thanks in advance.
151.145487,-33.796017,SPEED_CAMERA
151.089928,-33.849332,SPEED_CAMERA
151.008202,-33.800678,SPEED_CAMERA
151.158152,-33.812908,SPEED_CAMERA
151.207860,-33.794063,SPEED_CAMERA
151.170760,-33.752138,SPEED_CAMERA
151.225537,-33.752682,SPEED_CAMERA
151.247045,-33.807438,SPEED_CAMERA
151.243793,-33.813990,SPEED_CAMERA
150.932630,-33.823228,SPEED_CAMERA
151.023573,-33.835887,SPEED_CAMERA
151.022497,-33.815287,SPEED_CAMERA
150.962982,-33.816130,SPEED_CAMERA
150.963973,-33.816105,SPEED_CAMERA
151.230482,-33.876437,SPEED_CAMERA
151.092645,-33.886533,SPEED_CAMERA
151.104760,-33.887753,SPEED_CAMERA
151.114688,-33.913912,SPEED_CAMERA
151.181667,-33.945955,SPEED_CAMERA
151.131332,-34.035652,SPEED_CAMERA
151.008737,-33.904675,SPEED_CAMERA
150.965628,-33.891423,SPEED_CAMERA
150.894502,-33.898012,SPEED_CAMERA
150.855230,-33.902997,SPEED_CAMERA
151.027515,-33.940087,SPEED_CAMERA
151.009878,-33.979058,SPEED_CAMERA
151.049552,-33.960998,SPEED_CAMERA
151.083658,-34.037475,SPEED_CAMERA
151.232018,-33.822447,SPEED_CAMERA
151.068070,-33.773737,SPEED_CAMERA
151.049188,-33.782663,SPEED_CAMERA
151.101978,-33.803100,SPEED_CAMERA
151.038517,-33.740068,SPEED_CAMERA
151.245295,-33.810080,SPEED_CAMERA
150.979180,-33.869715,SPEED_CAMERA
151.136692,-33.967277,SPEED_CAMERA
151.136309,-33.968199,SPEED_CAMERA
151.369762,-33.353397,SPEED_CAMERA
151.349595,-33.413648,SPEED_CAMERA
151.326813,-33.490995,SPEED_CAMERA
151.319907,-33.503952,SPEED_CAMERA
151.430998,-33.439473,SPEED_CAMERA
151.319395,-33.420327,SPEED_CAMERA
151.613140,-33.133935,SPEED_CAMERA
151.342897,-33.358127,SPEED_CAMERA
151.295618,-33.481578,SPEED_CAMERA
151.474972,-33.371698,SPEED_CAMERA
151.692195,-32.983677,SPEED_CAMERA
151.697813,-32.907872,SPEED_CAMERA
151.458090,-32.699592,SPEED_CAMERA
152.730625,-31.582758,SPEED_CAMERA
153.010700,-30.503100,SPEED_CAMERA
151.677500,-30.449000,SPEED_CAMERA
153.338300,-29.076400,SPEED_CAMERA
153.405700,-28.729300,SPEED_CAMERA
153.449070,-28.409510,SPEED_CAMERA
151.682020,-32.925112,SPEED_CAMERA
151.729785,-32.892210,SPEED_CAMERA
151.703893,-32.856307,SPEED_CAMERA
151.704813,-32.857668,SPEED_CAMERA
150.864838,-32.039305,SPEED_CAMERA
150.895627,-31.783663,SPEED_CAMERA
150.821240,-31.756957,SPEED_CAMERA
150.860633,-31.459500,SPEED_CAMERA
151.042317,-31.061367,SPEED_CAMERA
150.632652,-33.533602,SPEED_CAMERA
150.795032,-33.628395,SPEED_CAMERA
150.797305,-33.661357,SPEED_CAMERA
150.591990,-33.711828,SPEED_CAMERA
150.170690,-33.543928,SPEED_CAMERA
150.913775,-34.331593,SPEED_CAMERA
150.913812,-34.330120,SPEED_CAMERA
150.892618,-34.411440,SPEED_CAMERA
150.900732,-34.377947,SPEED_CAMERA
150.900428,-34.377872,SPEED_CAMERA
150.883973,-34.406270,SPEED_CAMERA
150.881230,-34.414718,SPEED_CAMERA
150.761342,-34.742482,SPEED_CAMERA
150.729772,-34.763132,SPEED_CAMERA
150.686277,-34.774270,SPEED_CAMERA
150.605730,-34.857620,SPEED_CAMERA
150.876158,-34.491782,SPEED_CAMERA
150.731620,-34.844895,SPEED_CAMERA
148.185353,-34.906077,SPEED_CAMERA
147.770657,-35.239315,SPEED_CAMERA
150.604065,-34.869163,SPEED_CAMERA
150.869865,-34.427018,SPEED_CAMERA
150.892150,-34.389797,SPEED_CAMERA
149.194255,-35.373784,SPEED_CAMERA
149.829190,-36.519211,SPEED_CAMERA
149.836402,-36.630767,SPEED_CAMERA
Tim Buxton
PostPosted: Fri Apr 01, 2005 10:36 am    Post subject: Reply with quote
Wow, the first couple of lines would have done! The first problem is that the third column, SPEED_CAMERA, should say "SPEED_CAMERA". Can I ask how this database was created and what was used to edit it?
The second problem is that all your POIs have the same name. Ideally all POIs should be uniquely identified.
Tim
Golden_Monk
PostPosted: Fri Apr 01, 2005 12:04 pm    Post subject: Reply with quote
Not really sure how it was created, came to me in a csv file in this way.
They are speed cameras for Australia.
Tim Buxton
PostPosted: Fri Apr 01, 2005 12:19 pm    Post subject: Reply with quote
Well then it looks like you'll have to edit the file manually, I'm afraid. However you do iy, you need each SPEED_CAMERA to be "SPEED_CAMERA_XX"
Tim
Golden_Monk
PostPosted: Sun Apr 03, 2005 10:48 am    Post subject: Working but no notification... Reply with quote
Thanks Tim, I added the quotes and they now show up on the GPS software, but do not seem to be notifiying...could this be due to the fact they are all the same name?..I have only just changed the names now so won't know until tomorrow whether or not I get notified now.
Tim Buxton
PostPosted: Sun Apr 03, 2005 10:18 pm    Post subject: Reply with quote
It could be, I'm not sure. Are you sure you've set SmartST to notify you of Custom POIs? Press the left rocker then the arrow in the bottom right-hand corner. Tap Setup then use the arrows to get to the Active POI tab up. For each of your Custom POIs, you can set up a warning, but you can only do this if the "Active" box is ticked. (Even if they are not ticked, they will show on the screen; this is a known bug.)
Tim
22.064 (26 Jun 24)
