Joined: 13/03/2003 14:39:30 Posts: 31 Location: United Kingdom
Posted: Tue Mar 29, 2005 11:48 am Post subject: Install V5 & V3
Hi.
With the forthcoming version 5 of TomTom, I need some advice.
Is it possible to install both v5 and V3 to seperate SD cards. I need to know this as I have the maps of europe for V3 and although I wish to upgrade to v3 I do not visit france often enough to justify paying for europe maps again.
I would like to be able to swap SD cards and have france v3 on one UK v4 on the other.
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Tue Mar 29, 2005 1:08 pm Post subject:
I don’t think different version of TTN will work with each other’s maps but I think this may be possible using Sprite Backup PE ! I stand to be corrected by the more knowledgeable here.
If you make a self restoring backup of your PPC which contains tt v3 on the SD card that contains your maps of France before you upgrade to version 5 you should then be able to able to restore and use v3 when required., you would of course need to make a backup of your ppc which contains v5 on the second SD card that cotains the v5 maps in order to change back again.
BTW I used Sprite to revert back to 3.03 after problems with 3.07
dave
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Tue Mar 29, 2005 1:54 pm Post subject:
on the update from v2 to v3 you only had to pay one upgrade fee for uk and maps of WE - if you owned both.
if this is the case again then your upgrade to v5 will be all you need.
I guess when the upgrade fee's are published we'll find out - I'm in the same boat. _________________ -----------------------------------------------------------
TTN6.03 tomtom 7.xx (one)
