gjai Occasional Visitor
![](modules/Forums/images/avatars/gallery/095.gif)
Posted: Tue Aug 10, 2004 10:37 am Post subject: Hi-204e Problem : NO First Fix ! |
hi,
First, sorry for my English, I 'm French....
Yesterday i'm received my gps hi-204e, ... after having read manual , I connected gps receiver to my pda, dell axim 3xi.
Wait 20 min for the Time to First Fix .... and LED indicator continues flashing !!!!!!!!!
No sat , no tracking.
I also tested on my laptop, IBM 570e, but it is similar....
After six hours of exterior 's test, my gps is always with 24°N/121°E... no fix , no sat ,.... and time passes...
This morning ,I 've to contact HAICOM and my retailer, i wait an answer .
Please Help me ...
...If not, the mouse will return to it ... _________________ Dell Axim 3xi + Haicom Hi-204e GPS = no sats :p |
hackmaster Occasional Visitor
Posted: Wed Mar 23, 2005 2:05 pm Post subject: HI-204E Light constantly on! |
Hi Guys
Some help needed....
I have a IPAQ H5550 + HI-204E + TomTom3
it was working fine and i was well happy with it, whne it was working the light (red) would flash to indicate conectivity with satelites i presume.
it now does not work... the red light is constantly on and does not detect anything, says GPS position unrelaible...
im stuck as to wot to do...
help required please !! |
CHR15 Occasional Visitor
Posted: Wed Mar 23, 2005 7:30 pm Post subject: |
Have you guys tried the RESET FACTORY DEFAULT in the Haicom Viewer Utility?
Or a COLD RESTART in the same utility.
Also Query the firmware Revision to see if you can communitcate with it. |
Posted: Thu Mar 24, 2005 11:39 am Post subject: |
Sorry im a little new to this hardware, but not sure how I am able to do this? connect it to PC then? connect to IPAQ then reset?
your help is great thanks |
Skippy Pocket GPS Verifier
![](modules/Forums/images/avatars/7197988194d2507f52befb.jpg)
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Thu Mar 24, 2005 12:24 pm Post subject: Re: Hi-204e Problem : NO First Fix ! |
gjai wrote: | Wait 20 min for the Time to First Fix .... No sat , no tracking. |
A first fix from factory defaults should take less than 20 minutes in good conditions. After the first fix, it should be able to cold start in less than 1 minute.
Sorry to ask silly questions, but:
Are you outdoors in a place where your receiver has a GOOD view of 75% of the sky in all directions (not obscured by buildings, trees etc)?
If you are using the GPS in your car, does your car have a heat reflecting windscreen which is blocking the GPS signal? _________________ Gone fishing! |
scubakid Occasional Visitor
Posted: Fri Apr 22, 2005 12:20 pm Post subject: |
If it is "flashing" it has a fix
make sure you have the correct com port set up etc to comunicate with it.
John |
