Pocket GPS World :: View topic - Fatal Application error on Ipaq3870
vxer
PostPosted: Tue Mar 22, 2005 12:26 pm    Post subject: Fatal Application error on Ipaq3870 Reply with quote
After years of perfect operation, last week TTN came up with a FAE exception 0cc0000005 @ 01fb6948
I contacted TTNs desk who were quick to respond and initially told me to delete .cfg files - which I did. When this didn't work they advised a hard reset and complete re-install. This I did & whilst everything loads OK and goes through the TTN set up procedure, on first try the same error appears.
To me it points to an IPAQ problem BUT it seems to work perfectly on everything else and I have run out of ideas and am looking for inspiration. After two years I have now had to revert to a map in the car!!!!- nightmare!
Any help or suggestions would be gratefully received.
Thanx
Malcolm
I am (or was!) running 2002 with a Clip-on Bluetooth
Parky
PostPosted: Tue Mar 22, 2005 1:29 pm    Post subject: Reply with quote
Hi Malcolm,
Most of the fatal exception errors I have encountered have been down to POI corruptions, usually the bitmaps. Are you using any POI's on your system? It may pay you to also defrag your storage card as they can sometimes cause the same errors.
Alan
Mio P550 Mio 3 TTN 6 2GB SD Card, Ipaq 5450: Integral 1Gb SD card, TTN 6, POICapture, PPC 2003
howardr
PostPosted: Tue Mar 22, 2005 2:53 pm    Post subject: Reply with quote
I had exactly the same problem - nothing cleared it. Then I deleted some of the POI files that I'd downloaded (many from this site) and hey presto! everything's OK again.
vxer
PostPosted: Tue Mar 22, 2005 4:29 pm    Post subject: Thanks Reply with quote
Thanks for the feedback. I've reloaded and cleared the SD card and all seems well but I will have to activate the software - which will have to wait until I get home!
Malcolm
22.064 (26 Jun 24)
