Pocket GPS World :: View topic - GlobalSat SD 501 sdio receiver or replacement tomtom aerial
stvme2519
PostPosted: Sun Mar 13, 2005 10:33 am    Post subject: GlobalSat SD 501 sdio receiver or replacement tomtom aerial Reply with quote
ive bust the jack on my tomotm reciever so im gona have to replace it ive seen a GlobalSat SD 501 sdio receiver wich wil work on my pda so any ideas which shall i buy the global sat or the origanal tomtom
DavidW
PostPosted: Tue Mar 15, 2005 11:35 pm    Post subject: Reply with quote
There have been reports of compatibility issues with the SDIO GPS on some machines - and don't forget that you need somewhere to put your maps. If you have your maps on CompactFlash card, then an SDIO GPS is a possibility - but not one I'd recommend.
A replacement TomTom wired GPS shouldn't cost that much. If you want different hardware, I'd consider buying a Bluetooth GPS (assuming that you have a Bluetooth PDA).
nigelw
PostPosted: Fri Mar 18, 2005 1:22 am    Post subject: Reply with quote
Why would you not recommend a SDIO GPS?
I have a SDIO SD-501 and it's a very good GPS receiver. The only problem it has is that the SDIO connector to the Axim X50 is not robust enough to use for off-road cycling. Shocks disconnect the receiver.
If you don't intend to use the PDA/GPS combination in an environment where shock is a problem what is wrong with an SDIO GPS?
