Wizzard Occasional Visitor
Posted: Sat Mar 12, 2005 1:55 am Post subject: POI Icons Doing A Runner |
How annoying is this???
Has anyone else expericenced their MY POI icons going AWOL. My 510 has a nasty habit of NOT showing the POI icons on screen unless I go through the menu options to "show icons on screen" and save the changes, a bit of a nightmare when driving. Auto Zoom is a particular culprit so I've disabled it, a pity really because its usefull. I've tried using icons of all sizes and formats using photoshop without success so guys/gals I'm sure someone out there has the answer. |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Sat Mar 12, 2005 10:22 am Post subject: |
Are you running SP1? I though that this cured that particular problem on the 510. _________________ Tim |
Simon1 Frequent Visitor
Posted: Sat Mar 12, 2005 11:25 am Post subject: |
SP1 definately does cure this problem. |
Posted: Mon Mar 14, 2005 2:00 am Post subject: |
Thanks guys.
I'm sure that in a previous message someone discussed how to find out which version of the softare you are running and if indeed sp1 is loaded.
Can anyone remind me because as usual I can't find the message again. |
Posted: Mon Mar 14, 2005 9:43 am Post subject: |
Not having a 510, I don't know what numbers SP1 shows you, but if you connect your 510 to your PC and run Navman Desktop, then Click on Setup >Update Software >Check for Updates on the web. If there are any updates to be had, you will be informed and offered the opportunity to update; if not, you are already running the latest version. _________________ Tim |
