Pocket GPS World :: View topic - TOMTOM GO driving me mad
Trev
PostPosted: Sun Mar 13, 2005 1:40 pm    Post subject: TOMTOM GO driving me mad Reply with quote
I am on my second ttg since chrismas
my current unit is
app 4.420 (2852/041010) os:201
32 mb ram
gps v1.21.boot 1.35
map Great britain v390
lang English uk
sd card bytestor 512mb
O and Jane
The problem is
plan a route off I go the unit will be fine for a day or two then screen goes
blank then to red hands some times it replans the route other times it says no route planed
When I am in the middle journey it's annoying
been out friday it's getting more frequent
Thanks in advance for any help
Trev
Eldar
PostPosted: Sun Mar 13, 2005 2:34 pm    Post subject: Reply with quote
It sounds like an SD card problem. Either you 512mb card is malfunctioning (I take it it's not the original card which came with TTG) or it is not making a good contact inside the SD card holder.
Have you tried driving around with the original SD?
JohnBoy59
PostPosted: Sun Mar 13, 2005 8:51 pm    Post subject: Reply with quote
512mb card????? mine came with 128mb Confused
Life's a bitch... then I met Jane...
Wishlist
PostPosted: Sun Mar 13, 2005 8:53 pm    Post subject: Re: TOMTOM GO driving me mad Reply with quote
my current unit is
32 mb ram
gps v1.21.boot 1.35
lang English uk
O and Jane
The problem is
Trev
Dont suppose you have it sat by the heater vent do you?
Trev
PostPosted: Mon Mar 14, 2005 6:48 am    Post subject: Reply with quote
JohnBoy59 I up grade to 512mb card
Eldar no I have not tried yet good point
Wishlist yes to the screen vent but only when the heat is to the cabin and no over heating on ttg
Trev
SGR1913
PostPosted: Mon Mar 14, 2005 9:27 am    Post subject: Reply with quote
Your card is listed as not compatible with Tomtom GO
http://www.mytomtomgo.com/special_faq.php#77
Trev
PostPosted: Mon Mar 14, 2005 9:43 pm    Post subject: Reply with quote
I just had looked at my card it is bytestor 513mb hi-speed
Cards brands that WILL work with the GO
* A1
* ByteStor (Hi-speed)
* Dane-elec
* Expansys
* Integral
* Kingston
* Kodak
* Sandisk
* NCP
* PQ1
* Viking
Card brands that will NOT work with the GO
* Bystore
* ByteStor (normal speed)
* PNY
* Traxdata
Trev
Wishlist
PostPosted: Mon Mar 14, 2005 11:02 pm    Post subject: Reply with quote
If it’s not an SD card issue, & I suspect it is, then it could well be a power issue. Try running just on batteries a while and see if it keeps doing it.
Trev
PostPosted: Tue Mar 15, 2005 8:31 pm    Post subject: Reply with quote
monday moved ttg from the heater vents it worked ok all day
to day I did not set a route but had the ttg on
and on my way to work it went to start up three times it set a route to my home(favourite)
so I stop the route and removed the power lead
So now runing on it's own battery all is fine for half hour then it started again
has my ttg had it
Trev Sad
Eldar
PostPosted: Tue Mar 15, 2005 8:46 pm    Post subject: Reply with quote
That was with the original card?
Wishlist
PostPosted: Tue Mar 15, 2005 8:52 pm    Post subject: Reply with quote
Don’t give up just yet, you have to admit it does all appear to all point towards the card though!
Sad
If that still causes problems then it may well be a return. Unless anybody else can think of something I missed? Question
Trev
PostPosted: Tue Mar 15, 2005 9:06 pm    Post subject: Reply with quote
Eldar it's the 512 mb card
got to find the original card
Trev
22.071 (03 Jul 24)
