Pocket GPS World :: View topic - problem with checkPOInt
block
PostPosted: Sat Mar 12, 2005 12:29 pm    Post subject: problem with checkPOInt Reply with quote
i have an ipaq 1940 with tomtom navigator 3. i have loaded your gps camera programe & checkPOInt. i think i have loaded checkPOInt ok, but when i go into overlay settings to set up the voice commands (which i have saved in programe files\checkPOInt) the "sound to play as first warning" box has my documents \checkPOInt entered. how do i change this? also the file in overlay settings is not syncronized and the files have "no image" in front of them, is this correct? thanks:cry:
Parky
PostPosted: Sat Mar 12, 2005 1:04 pm    Post subject: Reply with quote
Hi Block,
It would be helpful if you can let us know which version of Checkpoint you are using. The recomended version is 2.0.2, and not 3.2 which has caused some users problems. Version 2.0.2 can be downloaded from this site. I use version 2.0.2, and to use the sound files you would do the following, on the first warning screen first check the "Give first warning" button. This then lets you use the "Sound to play as first warning" box. To input the sound you want touch the square box with the 3 dots in. This then lets you navigate to the folder were you have stored the sound. Simply highlight the sound you want to use, and it will play to confirm you have the correct one. You would do exactly the same for the Last Warning sound also.
As for the "no image" question and not being syncronised I cannot give an answer.
Mio P550 Mio 3 TTN 6 2GB SD Card, Ipaq 5450: Integral 1Gb SD card, TTN 6, POICapture, PPC 2003
block
PostPosted: Sat Mar 12, 2005 3:54 pm    Post subject: Reply with quote
thanks, I did have version 3.2 but have now downloaded 2.0.2 and have set up the sound files as you suggested, (havn't tried it on the road yet). any idea how to delete 3.2?
22.071 (03 Jul 24)
