Pocket GPS World :: View topic - Map switching and monitoring with Checkpoint
s3dbw
PostPosted: Sat Mar 12, 2005 11:48 am    Post subject: Map switching and monitoring with Checkpoint Reply with quote
As I regular use TomTom Navigator 3 and checkpoint across Europe, I have a number of European Maps installed. However I have organised the maps such that the relevant POI's for each country, eg speedcams are stored in the particular map for that country.
In this configuration Checkpoint will only see the POI's of the particular map that you use when it first starts, if you switch maps with the system on, when changing countries, it does not appear to automatically pick up the new POI's for that country, you need to shut the system down and restart on the relevant map.
Short of installing all the POI's for each country in every map, is there a way to get checkpoint to switch between maps without having to restart each time?
regards
s3dbw
PostPosted: Thu Mar 31, 2005 7:51 am    Post subject: Reply with quote
OK, done some experimenting.
After a hard reset and re-install, checkpoint was happy to switch maps each time TomTom changed, however after removing TomTom and re-installing it, Checkpoint for some reason then fails to switch the POI's that it is monitoring when TomTom changes maps?
Can anyone explain whats going on here, as I really dont want to do another hard reset and re-install everything again
22.101 (03 Oct 24)
