Darren Frequent Visitor
Posted: Tue Jul 06, 2004 5:10 pm Post subject: 24v Input Query |
In answer to a post on a Usenet forum I suggested that it may not be advisable to plug a GPS Mouse with cigarette lighter power plug into a 24 supply.
I've since been told that these adapters will happily accept input from 8v - 35v. Can any HGV drivers with 24v confirm this? I'm being cautious until I know better as if this is incorrect it would possibley mean 1 fried PPC and GPS! I thought the accessory outlets sold 24v - 12v converters specifically because of this but maybe the converters that come with GPS are just better designed to handle this range of inputs? _________________ Darren Griffin |
alix776 Pocket GPS Moderator
Posted: Wed Jul 07, 2004 12:33 pm Post subject: |
ive seen this around on the brodit site they say there mounts a 24v-12 compatablebut wouldnt like to try it the general rule of thumb is if your not sure use and voltage dropper and can be picked up for as little as £25 pound. personally i wouldnt try itunless id spoken to the manufacurer _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
mikeshe Lifetime Member
Posted: Sun Jul 11, 2004 4:45 pm Post subject: |
I have actually used mine in a truck using the TomTom Car Kit, plugged into the 24 volt lighter socket and everything was okay.
Mike |
Posted: Sun Jul 11, 2004 9:07 pm Post subject: |
Cheers, looks like it's OK then  _________________ Darren Griffin |
Gowjo Occasional Visitor
Posted: Sun Jul 18, 2004 6:22 pm Post subject: 12 or 24 |
In most trucks today you will find a switch on the dash that says 12/24 this enables to switch between 12 or 24 volt, i use my ipaq 2210 with tomtom 3 on the 12v and not a problem at all, it works fine, ive even switched it to 24 to test it, because the ciggy adaptor is fused there is no worry of damaging the system. hope this helps. |
quadman Occasional Visitor
Joined: Jan 27, 2005 Posts: 10 Location: Pattishall-uk
Posted: Mon Feb 07, 2005 7:06 pm Post subject: cigarette lighter |
I have always plugged my electronic devices into the cigarette lighter, basically your charger is a step down transformer. If you plug the charger in first without plugging into the device, you would see smoke from the charger.
I have never had a problem, you could get a voltage dropper or an adaptor for the 12 volt socket if you'd prefer.
That is if the lighter socket works though....... |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Mon Feb 07, 2005 8:15 pm Post subject: |
alix776 wrote: | ivoltage dropper can be picked up for as little as £25 |
Or you can buy a LM7812 voltage regulator for about £1.... _________________ Gone fishing! |
Dohnut Occasional Visitor
Posted: Thu Mar 10, 2005 6:36 pm Post subject: |
Word of advice and also a word of warning.
I had the same reservations about whether to plug into the 24v supply, so I obtained a 24/12v dropper which I keep with me at all times, works well, the Emtac charger, chargers both the Ipac 4150 Pda and the Emtac bluetooth Gps.
However one day I inadvertently plugged the charger directly into the 24v system on the truck, after about half an hour I realised what I had done. Oh joy of joy, no problem both the Pda and the Gps worked fine and still do, however I am still cautious and use the dropper, when I can be bothered to get it out.
Now for the caution, two days ago I plugged the charger in as usual to find that it was not working, no light on, so I got my backup charger out a Leadtek charger which clearly stated 12/24v on it. Two seconds later I smelt the distinctive smell of frying electronics, I quickly pulled the charger out. Too late the charger was well and truly cooked. Worse still it was in the 12v socket not the 24v. The only conclusion I could come with was that the on board dropper was connected the wrong way and was giving out 48volts and not 12v. Moral of this story is that I will always use the 24v plug, no dropper to screw it up.
What concerned me the most was that the fuse in the Leadtek charger had`nt blown. Bit of good luck though when I had a chance to check the fuse in the Emtac charger, it had blown, soon had the spare fuse in it and on and on and on.
Ipac 4150, Emtac Bluetooth Gps,
Backup Gps, Leadtek 9537 |
Gus607 Occasional Visitor
Posted: Sat Mar 12, 2005 9:38 am Post subject: |
I have used my TTG since last August plugged into a 24v cigar lighter socket on a truck, no problem. If the charger is rated 12/24v then all should be ok. |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Sat Mar 12, 2005 10:11 am Post subject: |
If anyone is worried about frying their precious bit of kit all that is required is to measure the voltage at the jack end of the power lead and if it matches the specs of the kit you are useing ( +ve or -ve pin and the correct voltage) then you should be OK Every one does have a meter don't they
Dave |
robertn Frequent Visitor
Posted: Mon Mar 14, 2005 4:51 am Post subject: |
There are a number of issues around putting 24V into a device designed for 12V. Components are rated for a specific voltage, sometimes they go pop immediately, sometimes they last longer. Most 12V devices will handle well over 12 Volt, but will be on or exceeding limits at 24V. Because it appears to work doesn't mean you are not damaging it. Also dropping 24Volts down to 12 can generate a lot of heat. It may take an hour of more to finally "let the smoke out".
Unless you know what you are doing, don't exceed the manufacturer spec. Also don't plug a 24V device into 12 volts. Nasty things can happen as well.
Remember that a 24V system is a nominal 24 Volt. They normally run at around 28 volts. It's not uncommon to see 30+V "spikes" in this environment. Unless a device is designed for 24V automotive, it's luck that keeps the smoke inside the components. |
Posted: Mon Mar 14, 2005 7:23 pm Post subject: |
Well, the sticker on my TTG charger states 24/12v input. But did I read somewhere that some TTGs shipped with a 12v charger only ?????????
If only 12v then don't connect to 24v. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Mon Mar 14, 2005 8:38 pm Post subject: |
Gus607 wrote: | Well, the sticker on my TTG charger states 24/12v input. But did I read somewhere that some TTGs shipped with a 12v charger only ?????????
Mine does as well. I believe some of the earlier units were only 12v.
As the 12/24v is only the nominal figure of a fully charged battery at rest, it is appreciated that charging circuits in vehicles have to go 'above' this voltage to charge. It can only be assumed that when marked up as 12/24 that they are designed with this higher voltage in mind, as are other electrical pieces for vehicles.
The regulator in a 12/24v must be of a good standard in that it can regulate over that larger voltage range, and to dissipate the extra power at the higher voltages.. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Mon Mar 14, 2005 10:38 pm Post subject: |
Oldboy wrote: | The regulator in a 12/24v must be of a good standard in that it can regulate over that larger voltage range, and to dissipate the extra power at the higher voltages.. |
Like this 40 cent one: http://www.fairchildsemi.com/pf/LM/LM7805.html
As Fairchild say: "internal current limiting, thermal shut-down and safe operating area protection, making it essentially indestructible"
They take up to 35 volts and give very good regulation. I have used lots of these in various types of equipment and after giving them a fair amount of abuse, I can confirm that they are pretty much bullet proof. They will simply shut down if you short circuit or over heat them. _________________ Gone fishing! |
Posted: Tue Mar 15, 2005 7:14 am Post subject: |
Skippy wrote: | Oldboy wrote: | The regulator in a 12/24v must be of a good standard in that it can regulate over that larger voltage range, and to dissipate the extra power at the higher voltages.. |
They take up to 35 volts and give very good regulation. I have used lots of these in various types of equipment and after giving them a fair amount of abuse, I can confirm that they are pretty much bullet proof. They will simply shut down if you short circuit or over heat them. |
Exactly. _________________ Richard
